How do I configure 4 T1's with the BE3000?
John Platts
Level 4
Level 4
We are proposing the BE3000 solution to a customer who has 4 PRI T1's, and the MCS 7890-C1 appliance only has 2 PRI T-1 ports. We are proposing a 2901 ISR at this site to terminate the other 2 PRI T1's. Can I have two of the 4 T1's terminated on the MCS 7890-C1 and the other two T1's terminated on the 2901 ISR? How do I configure the BE3000 to use all four PRI T1's?
gisriniv
You can terminate 2T1's to MCS 7890-C1and other 2 to 2901ISR
After you add the 2901ISR gateway go to sites page and associate 2901GW to that site.
paolo bevilacqua
4 T1s = 92 channel, with a normal phones/trunk allocation ratio, that makes 900 phones or so
(unless the number of  PRIs has been chosen by telco for sale purposes, or it is a call center).
In any case, are you sure that BE3000 is the right solution ?
gisriniv
