How do I fix Missed Call/Received Call numbers so that you can dial them from the menu correctly
angeolivier
Hello all,
I have some problem when i receive call the caller ID information are like this 123456678 and i can't dial this directly, i wan t to know how i can modify the caller ID to be display correctly to my IP phone like this 0123456678 or 00123456678 to direct dial
stephen
i'm not sure if its the best way, but i find the easiest way to add a translation-rule that add's the leading 0 onto the calling number.
voice translation-profile IncomingProfile
translate calling 50
voice translation-rule 50
rule 1 // /0/
This displays in your missed/received call with the extra 0 allowing you to return the call
Stephen
