01-19-2010 11:18 AM - edited 03-21-2019 02:02 AM
I have a IP Phone on my desk which I use as a primary. If I sit at another employees desk temporarily, how do I log into her phone to receive calls made to my extension?
Do I need to turn this feature on in the UC-540 first?
Phones are 7975G and 7925 cordless.
Thanks.
01-19-2010 11:22 AM
You could use Office Manager to control that other user call forward settings, and have his calls forwarded to you.
http://www.cisco.com/go/officemanager
Marcos
01-19-2010 11:28 AM
You could use extension mobility.
https://www.myciscocommunity.com/docs/DOC-1475
Be sure to check out the out of band configuration guide for your version of CCA.
