How is PLAR configured on a FXS port of a UC520 with code UC520-8.0.0? I am using a Viking E-40 Series Entry analog telephone plugged into an FXS port. It is a line powered speaker phones designed to provide two-way hands free communication from an entry door. I want the E-40 to automatically ring a hunt group when it goes off hook.
Solved! Go to Solution.
Thank you Steve.
Here is the final working commands I used. The hunt group was 505 and door extension was 301.
voice-port 0/0/0
timeouts ringing infinity
connection plar 505
station-id name Front Door
station-id number 301
ephone-hunt 5 sequential
pilot 505
list 201, 202, 203, 204, 208, 215, 243, 222
final 201
timeout 8, 8, 8, 8, 8, 8, 8, 8
no-reg pilot
statistics collect
description Front Door
How about CUCM 6.1 -I have the same e40 device
Do I do it via the new partition and CSS
Is the sation ID the Attendant DN?
I bascialy need to be able to dial into the viking e40 and press the button so it dials out.
