How to call a SIP-Address
roland.schaffer
Hi!
I have here a UC320 and a SPA525g2.
I can enter a SIP-Address into the private phone-book.
But it seems implossible to call it.
For example: sip:XYZ@ekiga.net is not reachable.
From the other end ekiga -> uc320 it is also impossible.
When i enter my full qualified sip-address into the ekiga phone it simply says: "Security check failed"
Whats most likely the problem?
Thanks!
wenyang
Level 4
Level 4
Hi Roland,
You need to configure the SIP trunk and the SIP trunk account number in the SIP/BRI Trunks page of the Configure Utility. And also configure the inbound calls and Outbound Trunks to let the inbound calls and outbound calls work properly.
Best regards,
Wendy
Hi Roland,
Forgot to mention, UC320W doesn't support SIP URI, it only supports phone number in E.164 format.
Best regards,
Wendy
Ah, this explains a lot. *sigh*
Thanks a lot!
Best regards,
Roland
