How to configure FXO/FXS port on UC560 for analog fax machine use?
rgordon-qsc
How can I assign one of my inbound DIDs, coming into my UC560 from my carrier's PRI, to be used for an analog device, such as a fax machine?
Do I do this by defining one of the FXS ports (i.e. 0/0/0) for a fax device?   Do I then need to connect FXO port 0/0/0 to the fax machine, or will the tone be generated from the FXS port?
Kevin Monteiro
Level 7
Level 7
This would be the setup, a fxs is where a end point terminate eg: fax-machine, analog phone.
A fxo is where a telco terminates a line.
Fax-machine>>>>fxs>>>uc560>>>PRI>>>PSTN
For a fxs port create a dial-peer:
Dial-peer voice 1 pots
Destinations pattern 4130 >>>>> this would be your fax number.
Port 0/0/0 >>>>> fxs port number
Kindly rate the post accordingly
Kevin
Sent from Cisco Technical Support Android App
