How to configure SPA525 and SPA502 to German
Support Albakom
Participant
Participant
Have some SPA525 and SPA502 configured with SCCP at an UC520 with German localization.
But unfortunately not all at the phone is in German. Only some softkeys appaears in german language, the rest still is english, also the whole menu and
some other softkeys.
I've upgraded the phones to Firmware 7.4.6 and copy the newest 7.4.6 XML Dictionary files into the flash of the UC. But it doesnt work.
How I get the phones to german?
Please dont provide me with suggestions using the CCA. This tool destroys my configured dial plan, dial-peers and so on. At least it doesnt allow two-digits extensions phones without users and so on.  However, I look a manually solution.
2 ACCEPTED SOLUTIONS
vcappucc
Beginner
Beginner
The process to localize the SPA525 Phone is:
1.- you need to extract from the spa525_dictXML_7_2_5.zip file the spa525_EN_7_2_5.xml (Yes you need to include English in the process in order to work) and spa525_DE_7_2_5.xml, anyhow I am attaching the 2 files into this email
2.-  Upload via (t)ftp the 2 files to the UC Flash
UC540#copy ftp flash
Address or name of remote host [192.168.10.111]?
Source filename [uc500.txt]? spa525_EN_7_2_5.xml
Destination filename [spa525_EN_7_2_5.xml]?
Accessing ftp://192.168.10.111/spa525_EN_7_2_5.xml...
Loading spa525_EN_7_2_5.xml !
[OK - 72099/4096 bytes]
72099 bytes copied in 6.808 secs (10590 bytes/sec)
Source filename [spa525_EN_7_2_5.xml]? spa525_DE_7_2_5.xml
Destination filename [spa525_DE_7_2_5.xml]?
Accessing ftp://192.168.10.111/spa525_DE_7_2_5.xml ...
Loading spa525_DE_7_2_5.xml!
[OK - 72328/4096 bytes]
3.- In telephony service configure the following:
UC540(config)#telephony-service
UC540(config-telephony)#user-locale DE
Updating CNF files
CNF files updating complete
UC540(config-telephony)#network-locale DE
Updating CNF files
CNF files update complete
4.- Tell the  Phones where to find the files:
Conf ter
tftp-server flash:/spa525_EN_7_2_5.xml alias English_United_States/525G-dictionary.xml
tftp-server flash:/spa525_DE_7_2_5.xml alias German_Germany/525G-dictionary.xml
end
5.- Finish
The procedure for 521 and 524,
1. download file CP_521_524_Dictionary.tar from:
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=UC500
2. copy files en_v_22_0_c.xml and fr_v_22_0_c.xml to flash
3. then paste:
conf t
tftp-server flash:en_v_22_0_c.xml alias English_United_States/524-dictionary.xml
tftp-server flash:fr_v_22_0_c.xml alias French_France/524-dictionary.xml
end
wr
and for the 50X will be, (sorry i had it in french, just use the correct dictionary)
The French Local files for the SPA50X phones are available here https://supportforums.cisco.com/docs/DOC-9931/
and the procedure is to copy this 2 files (enS_US_v615.xml and frS_FR_v615.xm) into UC500 Flash:
-    Please use FTP or HTTP to copy this 2 files, do not use tftp.
then
En
Conf ter
tftp-server flash:/enS_US_v615.xml alias English_United_States/50X-dictionary.xml
tftp-server flash:/frS_FR_v615.xml alias French_France/50X-dictionary.xml end wr
substitute the X for the correct phone type
*** example for a 504G Phone
*** tftp-server flash:/enS_US_v615.xml alias English_United_States/504-dictionary.xml
*** tftp-server flash:/esS_ES_v615.xml alias Spanish_Spain/504-dictionary.xml
Please notice that you will need the English Files as well
Then on telephony-service
UC540(config-telephony)#user-locale FR
Updating CNF files
UC540(config-telephony)#network-locale FR
Updating CNF files
Save your configuration And reload your phones.
please rate if this solves your question.
Thank you
Victor.-
BTW For Setting up the SPA525G2 Language you will need:
ephone  X
device-security-mode none
mac-address XXXX.XXXX.XXXX
max-calls-per-button 2
type 525G2
to French:
1.- you need to extract from the spa525_dictXML_7_2_5.zip file the spa525_FR_7_2_5.xml and spa525_EN_7_2_5.xml
2.-  Upload via (t)ftp the 2 files to the UC Flash, please use a protocol different than tftp.
Source filename [spa525_EN_7_2_5.xml]? spa525_FR_7_2_5.xml
Destination filename [spa525_NL_7_2_5.xml]?
Accessing ftp://192.168.10.111/spa525_NL_7_2_5.xml...
Loading spa525_NL_7_2_5.xml !
Updating CNF files
Updating CNF files
Conf ter
tftp-server flash:/spa525_FR_7_2_5.xml alias French_France/525G2-kate.xml
tftp-server flash:/spa525_EN_7_2_5.xml alias English_United_States/525G2-kate.xml
end
5.- Finish
18 REPLIES 18
Alberto Montilla
Dear Sir;
I've escalated your issue for resolution. Stay tuned.
Alberto
vcappucc
Beginner
Beginner
Updating CNF files
Updating CNF files
Conf ter
end
5.- Finish
3. then paste:
conf t
end
wr
then
En
Conf ter
Updating CNF files
Updating CNF files
Thank you
Victor.-
ephone  X
type 525G2
to French:
Updating CNF files
Updating CNF files
Conf ter
end
5.- Finish
thanks for answer.
I do it so and place the following commands for the phones after copying the files to UC flash:
UC520_LB(config)#tftp-server flash:/phones/525/spa525_en_v746.xml alias English_United_States/525G-dictionary.xml
UC520_LB(config)#tftp-server flash:/phones/525/spa525_de_v746.xml alias German_Germany/525G-dictionary.xml
Then I updated the user-locale and network locale in telephony-service.
I factory reset the phones.
Now: nothing softkeys are labeled. All are grey without fonts. The phone menu also all in english.
So I reboot the phones again and now it works. Thanks for help!
Hello Sir,
I am not sure if you got it working, if you need help please send your contact information to help you.
my email is vcappucc@cisco.com
Thank you
Victor.-
Hello Victor,
I'm trying to configure some 508G phones with a german locale. The tftp debug tells me:
Nov 30 11:28:24.655: TFTP: Looking for English_United_States/508-dictionary.xml
Nov 30 11:28:24.675: TFTP: Looking for German_Germany/508-dictionary.xml
Nov 30 11:28:24.679: TFTP: Opened flash:/phones/5x5/spa50x_30x_de_v746.xml, fd 15, size 51653 for process 181
Nov 30 11:28:24.875: TFTP: Finished flash:/phones/5x5/spa50x_30x_de_v746.xml, time 00:00:00 for process 181
Nov 30 11:28:25.955: TFTP: Looking for English_United_States/SCCP-dictionary.xml
Nov 30 11:28:25.963: TFTP: Opened flash:/its/united_states_SCCP-dictionary.xml, fd 15, size 2740 for process 181
Nov 30 11:28:25.975: TFTP: Finished flash:/its/united_states_SCCP-dictionary.xml, time 00:00:00 for process 181
Nov 30 11:28:26.043: TFTP: Looking for German_Germany/SCCP-dictionary.xml
Nov 30 11:28:26.047: TFTP: Opened flash:/its/germany_SCCP-dictionary.xml, fd 15, size 2988 for process 181
Nov 30 11:28:26.059: TFTP: Finished flash:/its/germany_SCCP-dictionary.xml, time 00:00:00 for process 181
configuration is as following:
tftp-server flash:/phones/5x5/spa50x_30x_de_v746.xml alias German_Germany/508-dictionary.xml
telephony-service
user-locale 0 DE
network-locale 0 AT
user-locale 1 US
network-locale 1 US
ephone-template 10
user-locale 0
network-locale 0
ephone 1
ephone-template 10
Some buttons and the Services-Menu are still in English. Any ideas?
kind regards,
Alfred
Dear Alfred;
Services menu will stay in English, this is a system limitation that will be addressed on SW pack 8.6 scheduled for next calendar year.
For the other buttons, can you please explain which ones stay in English?
Alberto
Hi Alberto,
Thanks for your fast answer - so my customer has to wait for the next update...
I didn't check all buttons, but DND, LiveRecord and more remain english - although I prefer "LiveRcd" over "???" (the german version on 79xx phones).
If you need more information, tell me and I'll check.
kind regards,
Alfred
Perhaps there is no need to wait until the offical fix, and I am not sure if this would help you, but as a workaround what we did was to:
UC560# conf ter
Enter configuration commands, one per line.  End with CNTL/Z.
UC560(config)#telephony-service
UC560(config-telephony)#cnf-file location flash:
UC560(config-telephony)#cnf-file perphone
UC560(config-telephony)#user-locale DE
UC560(config-telephony)#end
Then we found on the flash in the its directory
UC560#show flash:
203          0 Jan 22 2010 14:54:48 its
204         56 Jan 22 2010 14:58:32 its/SEPDEFAULT.cnf
205       4067 Jan 22 2010 14:58:34 its/XMLDefault.cnf.xml
206        903 Jan 22 2010 14:58:34 its/united_states_7960-tones.xml
207       8777 Jan 22 2010 14:58:34 its/united_states_7960-font.xml
208       1313 Jan 22 2010 14:58:34 its/united_states_7960-kate.xml
209      19750 Jan 22 2010 14:58:36 its/united_states_7960-dictionary.xml
210       2740 Jan 22 2010 14:58:36 its/united_states_SCCP-dictionary.xml
211       8777 Jan 22 2010 14:59:12 its/germany_7960-font.xml
212       1327 Jan 22 2010 14:59:12 its/germany_7960-kate.xml
213      20815 Jan 22 2010 14:59:12 its/germany_7960-dictionary.xml
214      26885 Jan 22 2010 14:59:12 its/germany_7905-dictionary.xml
215       2907 Jan 22 2010 14:59:14 its/germany_SCCP-dictionary.xml
now we copy all the content of the germany_SCCP-dictionary.xml into a  notepad and edit it to what should have
UC560#more flash:its/germany_SCCP-dictionary.xml
then we
UC560#
UC560#conf ter
UC560(config)#ip ftp username cisco
UC560(config)#ip ftp passw cisco
UC560(config)#exit^Z
UC560#
UC560#copy ftp://192.168.10.11 flash:/its/
Source filename []? germany_SCCP-dictionary.xml
Destination filename [/its/germany_SCCP-dictionary.xml]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
Accessing ftp://192.168.10.11/germany_SCCP-dictionary.xml...
Loading germany_SCCP-dictionary.xml !
[OK - 2989/4096 bytes]
The phone booted up with the Eddited word we changed
000424: TFTP: Looking for SEP002584D8CEDB.cnf.xml
000425: TFTP: Opened flash:/its/SEP002584D8CEDB.cnf.xml, fd 14, size 1405 for process 147
000426: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-2:AN2414F55422001 IP:10.1.10.2 Socket:2 DeviceType:Phone has unregistered abnormally.
000427: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-3:AN2414F55422002 IP:10.1.10.2 Socket:5 DeviceType:Phone has unregistered abnormally.
000428: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-4:AN2414F55422003 IP:10.1.10.2 Socket:3 DeviceType:Phone has unregistered abnormally.
000429: TFTP: Finished flash:/its/SEP002584D8CEDB.cnf.xml, time 00:00:00 for process 147
000430: TFTP: Looking for spa5x5-7-4-2.BIN
000431: TFTP: Opened flash:/phones/5x5/spa5x5-7-4-2.bin, fd 14, size 3477171 for process 147
000432: TFTP: Looking for RingList.xml
000433: TFTP: Opened flash:/ringtones/RingList.xml, fd 15, size 2823 for process 209
000434: TFTP: Finished flash:/ringtones/RingList.xml, time 00:00:00 for process 209
000435: TFTP: Looking for DistinctiveRingList.xml
000436: TFTP: Opened flash:/ringtones/DistinctiveRingList.xml, fd 15, size 2823 for process 209
000437: TFTP: Finished flash:/ringtones/DistinctiveRingList.xml, time 00:00:00 for process 209
000438: TFTP: Looking for German_Germany/7960-kate.xml
000439: TFTP: Opened flash:/its/germany_7960-kate.xml, fd 15, size 1327 for process 209
000440: TFTP: Finished flash:/its/germany_7960-kate.xml, time 00:00:00 for process 209
000441: TFTP: Looking for English_United_States/509-dictionary.xml
000442: TFTP: Looking for German_Germany/509-dictionary.xml
000443: TFTP: Looking for English_United_States/SCCP-dictionary.xml
000444: TFTP: Opened flash:/its/united_states_SCCP-dictionary.xml, fd 15, size 2740 for process 209
000445: TFTP: Finished flash:/its/united_states_SCCP-dictionary.xml, time 00:00:00 for process 209
UC560#
000446: TFTP: Looking for German_Germany/SCCP-dictionary.xml
000447: TFTP: Opened flash:/its/germany_SCCP-dictionary.xml, fd 15, size 2989 for process 209
000448: TFTP: Finished flash:/its/germany_SCCP-dictionary.xml, time 00:00:00 for process 209
UC560#
000449: TFTP: Looking for /SPA509G-cfg.xml
UC560#
000450: %IPPHONE-6-REG_ALARM: Name=SEP002584D8CEDB  Load=7.4.2 Last=Cold+CMERequested
000451: %IPPHONE-6-REGISTER: ephone-5:SEP002584D8CEDB IP:10.1.1.11 Socket:2 DeviceType:Phone has registered.
UC560#
000452: %IPPHONE-6-REGISTER: ephone-2:AN2414F55422001 IP:10.1.10.2 Socket:3 DeviceType:Phone has registered.
000453: %IPPHONE-6-REGISTER: ephone-3:AN2414F55422002 IP:10.1.10.2 Socket:4 DeviceType:Phone has registered.
000454: %IPPHONE-6-REGISTER: ephone-4:AN2414F55422003 IP:10.1.10.2 Socket:5 DeviceType:Phone has registered.
UC560#
000455: TFTP: Finished flash:/phones/5x5/spa5x5-7-4-2.bin, time 00:00:25 for process 147
UC560#
please let us know your findings.
Hi Victor,
Actually that is exactly the content of the germany_SCCP-dictionary.xml on the UC500-box.
kind regards,
Alfred
Hi Alfred,
please send me your show tech voice (vcappucc@cisco.com) and your contact information
in the email please indicate the ephones with language issue.
thank you
Victor.-
Hi Victor,
I sent you the requested information.
kind regards,
Alfred
Hello Sir,
Thank you for your email,
please try using 7-4-6,  http://www.cisco.com/cisco/software/pub/details.html?imageGuId=4B3BD33A13739B449785A1C8984056E9E3122356&flowid=5301&addoption=DN&isLatestRel=Y
we also see:
CONFIG [Version=8.0]
  Version 8.0
  Mode is srst
  Max-pool is 0
  Max-dn is 0
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  timeout interdigit 0
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
please try to set this on your system
R2(config)#telephony-service
R2(config-telephony)#network-locale DE
Updating CNF files
R2(config-telephony)#user-locale DE
Updating CNF files
R2(config-telephony)#no create cnf-files
R2(config-telephony)#cnf perphone
R2(config-telephony)#cnf loca fla
R2(config-telephony)#create cnf-files
Creating CNF files
then copy the files deS_v615.xml and enS_US_v615.xml (not using tftp) that are available @ https://supportforums.cisco.com/docs/DOC-9931 and
and
en
conf ter
no tftp-server flash:/phones/5x5/spa50x_30x_de_v746.xml alias German_Germany/508-dictionary.xml
tftp-server flash:/enS_US_v615.xml alias English_United_States/508-dictionary.xml
tftp-server flash:/deS_v615.xml  alias German_Germany/508-dictionary.xml
end
wr
also please reset your 3 508G to factory.- and  if you still have issues capture the deb tftp events and send us this output, with the show ephone phone.
with regards,
Victor.-
Hi Victor,
I did all the steps you requested - no success. What is the difference between copying via tftp and ftp?! I did it via ftp this time.
Have a look on the tftp debug output:
Nov 30 17:58:26.827: TFTP: Looking for SEP0002FDFFB6C5.cnf.xml
Nov 30 17:58:26.827: TFTP: Opened flash:/its/SEP0002FDFFB6C5.cnf.xml, fd 14, size 1422 for process 151
Nov 30 17:58:26.835: TFTP: Finished flash:/its/SEP0002FDFFB6C5.cnf.xml, time 00:00:00 for process 151
Nov 30 17:58:26.847: TFTP: Looking for spa5x5-7-4-6.BIN
Nov 30 17:58:26.847: TFTP: Opened flash:/phones/5x5/spa50x-30x-7-4-6.bin, fd 14, size 3859574 for process 151
Nov 30 17:58:26.903: TFTP: Looking for English_United_States/508-dictionary.xml
Nov 30 17:58:26.903: TFTP: Looking for RingList.xml
Nov 30 17:58:26.907: TFTP: Opened flash:/ringtones/RingList.xml, fd 15, size 2823 for process 211
Nov 30 17:58:26.947: TFTP: Looking for German_Germany/508-dictionary.xml
Nov 30 17:58:26.947: TFTP: Opened flash:/phones/5x5/deS_v615.xml, fd 16, size 45726 for process 181
Nov 30 17:58:26.959: TFTP: Finished flash:/ringtones/RingList.xml, time 00:00:00 for process 211
Nov 30 17:58:26.975: TFTP: Looking for DistinctiveRingList.xml
Nov 30 17:58:26.979: TFTP: Opened flash:/ringtones/DistinctiveRingList.xml, fd 15, size 2823 for process 211
Nov 30 17:58:26.995: TFTP: Finished flash:/ringtones/DistinctiveRingList.xml, time 00:00:00 for process 211
Nov 30 17:58:27.139: TFTP: Finished flash:/phones/5x5/deS_v615.xml, time 00:00:00 for process 181
Nov 30 17:58:28.059: TFTP: Looking for English_United_States/SCCP-dictionary.xml
Nov 30 17:58:28.059: TFTP: Opened flash:/its/united_states_SCCP-dictionary.xml, fd 15, size 2740 for process 181
Nov 30 17:58:28.071: TFTP: Finished flash:/its/united_states_SCCP-dictionary.xml, time 00:00:00 for process 181
Nov 30 17:58:28.143: TFTP: Looking for German_Germany/SCCP-dictionary.xml
Nov 30 17:58:28.143: TFTP: Opened flash:/its/germany_SCCP-dictionary.xml, fd 15, size 2907 for process 181
Nov 30 17:58:28.159: TFTP: Finished flash:/its/germany_SCCP-dictionary.xml, time 00:00:00 for process 181
Nov 30 17:58:30.159: TFTP: Looking for /SPA508G-cfg.xml
Nov 30 17:58:51.859: TFTP: Finished flash:/phones/5x5/spa50x-30x-7-4-6.bin, time 00:00:25 for process 151
On the phone, some soft-buttons are still in english, also the directories menu is completely in english.
kind regards,
Alfred
