12-15-2010 03:43 PM - edited 03-21-2019 03:25 AM
Hey guys,
I have a client who is having a tough time hearing some calls on the SPA501G handsets that we installed for him at his site. I know that you can increase the gain of some handsets after those handsets are web writeable, but as the 501Gs do not have a display, how can this be acheived on these units?
If it's helpful at all, the phone system is making use of it's FXO ports, so if we can simply increase the gain on those ports, that might work also.
Thanks!
Seth
12-17-2010 04:13 PM
Does anybody have information on how to increase the volume? I can't seem to find any documentation or procedure anywhere. Are there any Cisco Engineers who would like to comment?
Seth
12-17-2010 05:23 PM
I'm guessing you have already tried pressing the volume button?
12-20-2010 07:44 AM
Hi Marcus,
Yes, I've tried the volume button. :-) Many of these phones have the ability to increase or decrease the gain settings on the phone itself. It increases (or decreases) max and min volumes for a particular handset. This is the setting that I am looking for. Just cranking the handset volume up to max does not provide enough volume for my clients' needs.
Seth
12-27-2010 09:23 AM
Is there really no way to increase the gain settings on the telephone handsets? Anybody?
12-28-2010 06:51 AM
IF you are useing FXO ports the following link will help you out. Just rember this will effect the whole port.
http://cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080477a06.shtml
I would recommend looking the the version of firmware you have on phone and if it is not the latest upgrade to latest and see if that makes a difference.
