12-15-2009 07:20 AM - edited 03-21-2019 01:55 AM
Hello all,
Want to know how i cant lock or make authentication to the IP phone (7931,7911,7941) and how activate a ssl
thanks
12-16-2009 06:04 AM
The Cisco 7900 Series does not support an embedded SSL client.
Marcos
12-17-2009 02:41 AM
Ok no ssl but is not possible to lock a phone ?
12-17-2009 08:34 AM
Lock it web access you mean? If so, this is there by default (authentication challenge).
Marcos
01-20-2010 09:45 AM
Same question.
I would like to lock some 7961s and 7911s with a password, so that when the user leaves the desk, no one else can use the phone.
Tks.....
01-20-2010 10:05 AM
If you don't use Extension Mobility, you do not have a choice.
You could use Office Manager to temporarily restrict call permissions and disable voicemail for that user:
http://www.cisco.com/go/officemanager
Marcos
01-20-2010 10:28 AM
Oooops,, hehe
OK,,,
Gracias,,,
