10-20-2015 03:56 PM - edited 03-21-2019 08:47 AM
Hi All,
One of our customer wants to migrate their existing UC540 to Cisco BE6000S. Is there anybody who knows how to read the configuration of UC540 without login the router? UC540 doesn't support CLI, can I import the configuration into CCA tool to read it?
Thanks in advance.
Eric
10-21-2015 02:10 AM
UC540s have CLI access its just STAC wont support it if you configure it that way but you can console in and pull the config same as any other router
10-22-2015 03:48 PM
Hi Mark,
Thanks for the reply.
Can I see the output of “show run” via notepad or word?
Eruic
10-23-2015 12:36 AM
Hey yes login to the router and then set the router to log all commands then run a show run
http://kb.site5.com/shell-access-ssh/putty/putty-how-to-create-a-log-file-of-your-putty-session/
