02-26-2011 11:28 PM - edited 03-21-2019 03:44 AM
Lacking any ability to see/play/delete/save my UC500 voicemails in Gmail, I've created a google gadget for the side of Gmail so it is now possible to view my email and voicemail on the same page, this can also be added to an iGoogle homepage. Only tested on my own UC500 so would be interested in knowning if this works for anyone else, bugs etc.. It requires the UC500 to allow external connections via IMAP to the Voicemail module. (nat port 143 to the voicemail module and open the port in the firewall) You can also add it to your iGoogle Page To setup in Gmail and for more information: http://ec2-75-101-253-109.compute-1.amazonaws.com/ Also works with Cisco Unity Connection (I've tested version 7). Thoughts? | |
06-30-2011 01:44 AM
excellent, thanks for sharing that kind of helpful information.
Cheers,
MAR
08-26-2011 01:10 PM
It looks like that link isn't working anymore, is this gadget still working?
08-28-2011 04:28 PM
Yes this is still working, the web server failed to start on reboot (Amazon forced?), issue resolved.
08-29-2011 01:38 PM
Great. It works with ver 8 unity connection.
10-15-2011 09:59 PM
OK I tired this looks like it works on Unity Connect 8.5 Not quite a complete solution. The media player does not always play the message all the way thru, sometimes it wont play the entire messate. I want to know in what method is the password encrypted or stored. I think it has potential but not quite ready for Enterprise
10-17-2011 02:23 PM
The password is stored using the Google API for application settings. So it is stored under your google username/password. I am not sure how Google encrypt their settings but am sure it will be a robust solution.
08-21-2013 08:39 AM
Do you still have this app, and will it allow voicemails that have been read in Gmail to somehow send a notification back to Unity connection to shut off MWI's?
08-21-2013 08:59 AM
Sure, if you wish you can reach out to me directly
