Hi all,
We have an odd issue where several calls come in with the caller ID set as 9911. I am not sure why this is happening but the main problem is several internal users accidentally redial that number which calls the police and we get charged for a little visit by the men in blue.
I know it has to do with my dial peers for my inbound FXO ports but I can't seem to figure out how to fix it, here are my dial-peers:
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 400
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
b2bua
codec g711ulaw
no vad
dial-peer voice 2010 voip
description dial-peer for prompt management
destination-pattern 402
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** FXO pots dial-peer **-Emergency dial-peer
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 51 pots
preference 5
destination-pattern 911
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 52 pots
corlist outgoing call-local
preference 5
destination-pattern 9[2-9]..[2-9]......
port 0/1/0
forward-digits 10
no sip-register
dial-peer voice 53 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 54 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
prefix 011
no sip-register
dial-peer voice 55 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 56 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 57 pots
preference 5
port 0/1/1
forward-digits 10
no sip-register
dial-peer voice 58 pots
preference 5
port 0/1/1
prefix 1
no sip-register
dial-peer voice 59 pots
preference 5
port 0/1/1
prefix 011
no sip-register
dial-peer voice 60 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 61 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 62 pots
preference 5
port 0/1/2
forward-digits 10
no sip-register
dial-peer voice 63 pots
preference 5
port 0/1/2
prefix 1
no sip-register
dial-peer voice 64 pots
preference 5
port 0/1/2
prefix 011
no sip-register
dial-peer voice 65 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 66 pots
preference 5
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 67 pots
preference 5
port 0/1/3
forward-digits 10
no sip-register
dial-peer voice 68 pots
preference 5
port 0/1/3
prefix 1
no sip-register
dial-peer voice 69 pots
preference 5
port 0/1/3
prefix 011
no sip-register
dial-peer voice 100 pots
preference 5
port 0/2/0
forward-digits 3
no sip-register
dial-peer voice 101 pots
preference 5
port 0/2/0
forward-digits 3
no sip-register
dial-peer voice 102 pots
preference 5
port 0/2/0
forward-digits 10
no sip-register
dial-peer voice 103 pots
preference 5
port 0/2/0
prefix 1
no sip-register
dial-peer voice 104 pots
preference 5
port 0/2/0
prefix 011
no sip-register
dial-peer voice 105 pots
preference 5
port 0/2/1
forward-digits 3
no sip-register
dial-peer voice 106 pots
preference 5
port 0/2/1
forward-digits 3
no sip-register
dial-peer voice 107 pots
preference 5
port 0/2/1
forward-digits 10
no sip-register
dial-peer voice 108 pots
preference 5
port 0/2/1
prefix 1
no sip-register
dial-peer voice 109 pots
preference 5
port 0/2/1
prefix 011
no sip-register
dial-peer voice 110 pots
preference 5
port 0/2/2
forward-digits 3
no sip-register
dial-peer voice 111 pots
preference 5
port 0/2/2
forward-digits 3
no sip-register
dial-peer voice 112 pots
preference 5
port 0/2/2
forward-digits 10
no sip-register
dial-peer voice 113 pots
preference 5
port 0/2/2
prefix 1
no sip-register
dial-peer voice 114 pots
preference 5
port 0/2/2
prefix 011
no sip-register
dial-peer voice 115 pots
preference 5
port 0/2/3
forward-digits 3
no sip-register
dial-peer voice 116 pots
preference 5
port 0/2/3
forward-digits 3
no sip-register
dial-peer voice 117 pots
preference 5
port 0/2/3
forward-digits 10
no sip-register
dial-peer voice 118 pots
preference 5
port 0/2/3
prefix 1
no sip-register
dial-peer voice 119 pots
preference 5
port 0/2/3
prefix 011
Can anyone help me so that the caller ID doesn't show up as 9911?
Jorge
Solved! Go to Solution.
What might be happening here is that the inbound call is matching the FXO dial peer with destination pattern 9911, which is being put in the calling address field due to the fact that CLID is not being passed from the Telco. TO test this hypothesis, shut down all dial peers with destination pattern 9911 and make the call again.
Marcos
The port configuration that you show is actually for the FXS ports, not the FXO.
Would you mind posting your whole config and just remove the passwords?
Also, this might not be a problem on the UC config, it could be the calls are actually coming with this as the caller ID information.
This isn't part of the config. The next thing we can do is get some debugs of an inbound call or call your PSTN provider.
Marcos
Yeah, the telco is definetly part of the problem. We think it is because we have roll-over numbers on our block and some of the lines are dead so they get skipped. We are working with them currently to try to get Caller ID linked on all the lines as my boss thinks only some of the numbers in the block have the callerID tag on them.
Marcos,
How do I go about disabling the Dial-Peers through the CLI?
Jorge
Do "shutdown" under dial peer config.
Let us know,
Marcos
That worked! Now my question is what impact does that have on my system to leave those dial-peers shut down?
Jorge
That is not the fix. If you leave them shut down, they cannot be used for outbound calls. Try this:
1) Put the ALL_FXO trunkgroup under dial peers 50-53
2) Do a "no shutdown" of the peers you disabled
3) Test inbound calls repeatedly
We will need to enhance CCA in order to account for this use case. Let me know.
Marcos
Or you could ask your Telco to enable CLID on those lines, which they will be happy to do for a nominal fee ;-)
Marcos
