Initiate no battery-reversal
mhebert
I have just upgraded to CCA 3.0 and in the process it blew out my settings. I've got everything back except the no battery-reversal I need.
I'm able to telnet in through putty and issue some simple show comands (show ephone). If I type   "voice-port 0/1/0" exclude qutation marks, it doesn't like the v with the error point at the first letter. Ant Ideas? I have a UC520
Darren DeCroock
Level 4
Level 4
With CCA 3.0, you can change the battery-reversal options from within CCA.  Go to Configure > Telephony > Ports and Trunks > PSTN Trunks  - Choose the FXO port, and click "edit settings".   Battery-reversal option is listed there.
bethingt
are you in config mode?
Brian
Darren DeCroock
Level 4
Level 4
Thanks for the quick response and it was perfect
