I need to integrate a SPA232D, to which they would be connecting two SPA302D with a UC560.
I know through the CEC can not be done, but I guess if it can be done via CLI.
Can anyone tell me the command lines necessary to do this?
Hello Sir,
Unfortunately the SPA232D and the SPA302 are not a configurable device on the UC560 through CCA or CLI (Not supported). The only other option that may work, would be to use the FXS ports of the UC560 to connect to the FXO of the SPA232D. This should allow you to use the SPA302's as a analog extension.
Dennis, in this case, what are the options that I check or configure the SPA302 that can function as an analog extension of the UC560
thanks in advance
You can configre these as third-party SIP phones using CLI.
