04-07-2012 08:11 PM - edited 03-21-2019 05:37 AM
Hi friends,
I´ve never installed and configured the UC320,I did the topology to explain the scenario.So i have some doubts:
- Can I integrate the UC320 with PABX Traditional?
- Can make a call, source the analog phone connected to PABX to IP phone connected to UC320 ?
- Can I register phones and do the calls over VPN?
Tks
Solved! Go to Solution.
04-09-2012 08:58 AM
Thiago,
In reference to your attached uc320-topology.jpg, the UC320W only supports SPA500 series IP Phones and 1 connected analog device connected to the fxs port. PAP2T is not an option to register to the UC320W.
If you are looking to add SIP trunking to a traditional PBX, then SPA8000 and SPA8800 should be considered and used to register to SIP provider.
Randy
04-09-2012 08:58 AM
Thiago,
Randy
04-22-2012 03:21 PM
Ok thanks Man!!
