Inter-VLAN routing on UC540
dhsnodgrass
I have a UC540 that is connected to a single SG300-28P via the expansion port. I have 5 VLANs and 5 subnets (one for each VLAN). Each has a configured DHCP Pool and VLAN on the UC540. I can ping all of the VLAN interfaces from the switch ports on the UC540 (Ports 0/0-0/7) but when connected to the expansion port from the SG300 switch I can not ping back to the VLAN interfaces.
The VLANs and trunk are working because I can setup an access port for any of the ports on the SG300 and get the appropriate IP based on it's conifgured VLAN and I can ping the VLAN interface it is connected too, but cannot ping any of the other networks.
Any ideas what I might be missing from the configuration?
7 Replies 7
David Trad
Hi David,
Can you tell us what the SmartPort role has been setup for? You can best achieve this in CCA, make sure that the switch is part of the group and then go to the smart port settings, find out its role and then advise on here
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David,
The smartport is currently showing as a switch via the CCA.
dhsnodgrass
Did I leave information out that was needed for this?
David Trad
Hi David,
Sorry I haven't replied yet... I'm out of town and just haven't had a chance tho get back to you yet.
Can you post your config by any chance and just remove any sensitive information from it.
Cheers,
David.
Sent from Cisco Technical Support Android App
Current configuration : 32076 bytes
! Last configuration change at 20:26:09 CDT Thu Sep 13 2012 by cisco
! NVRAM config last updated at 20:19:13 CDT Thu Sep 13 2012 by cisco
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC540
boot-start-marker
boot-end-marker
card type t1 0 2
enable secret 4 gen5RuvupsY2P477INMgE6BCBGVDoKq6c84oXARc2vk
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
crypto pki trustpoint TP-self-signed-1686638308
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1686638308
revocation-check none
rsakeypair TP-self-signed-1686638308
crypto pki certificate chain TP-self-signed-1686638308
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363836 36333833 3038301E 170D3132 30393130 30323435
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36383636
  33383330 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C822 BC90933C 85EA5E68 D8728620 E968BC32 6EA1435F 090087BF 4AF9D400
  A08B76C5 5408A8CE 2EC2B449 AD3A45BC 5F14A076 72F48506 33B7C290 A63D0F89
  CCF7134F 1BE51C06 3D47AAF4 3356D7D8 D2B8BFAE 1567E8D2 E05EE5C6 056A6892
  6D6DB65B B5F03E66 3C0BDACB D427D935 992FD624 94D096DE FD01D5D1 60744157
  7CF30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 149EC15B F9504211 3B22F2F5 B153F01E 149F6D2B 52301D06
  03551D0E 04160414 9EC15BF9 5042113B 22F2F5B1 53F01E14 9F6D2B52 300D0609
  2A864886 F70D0101 05050003 8181000A 53C47BC8 40346D1A E7832782 1951B8A5
  14BCFD01 7AEFE73A 7C22CC63 E132C842 FFEE16E1 464F2758 03EBADA8 989B255A
  014EAD01 5ACBF11B 293D3773 BC008040 1E2F4862 21C143B0 73F98C95 BDD665D5
  E344FDF7 FDAC839B 3CEB7ABD 7B879007 511305F0 F611C41D B735DCFE 6C451C9C
  C07680D2 672B6747 717BD855 7A4EE2
        quit
dot11 syslog
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.100.1 10.1.100.9
ip dhcp excluded-address 10.1.100.241 10.1.100.255
ip dhcp excluded-address 10.1.1.1 10.1.1.35
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
network 10.1.100.0 255.255.255.0
default-router 10.1.100.1
option 150 ip 10.1.100.1
ip dhcp pool data
import all
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
ip dhcp pool office-wireless
import all
network 10.1.2.0 255.255.254.0
default-router 10.1.2.1
ip dhcp pool admin
import all
network 10.1.4.0 255.255.255.0
default-router 10.1.4.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-ni
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.100.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
create profile sync 0003542256834006
voice translation-rule 4
rule 15 /^...$/ /5126009848/
voice translation-rule 5
rule 1 /5126009844/ /203/
voice translation-rule 6
rule 1 /5126009843/ /399/
voice translation-rule 7
rule 1 /5126009845/ /399/
rule 2 /5126009846/ /399/
rule 3 /5126009847/ /399/
rule 4 /5126009848/ /399/
rule 5 /5126009849/ /399/
voice translation-rule 8
rule 1 /5126009850/ /399/
rule 2 /5126009851/ /399/
rule 3 /5126009852/ /399/
rule 4 /5126009853/ /399/
rule 5 /5126009854/ /399/
rule 6 /5126009855/ /399/
rule 7 /5126009856/ /399/
rule 8 /5126009857/ /399/
rule 9 /5126009858/ /399/
rule 10 /5126009859/ /399/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2000
rule 1 /5126009842/ /399/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PRI0-OP_Called_6
translate calling 3265
translate called 6
voice translation-profile PRI1_Called_5
translate called 5
voice translation-profile PRI2-OP_Called_7
translate called 7
voice translation-profile PRI2-OP_Called_8
translate called 8
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile VM_Profile
translate called 2000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FGL1625200U
archive
log config
  logging enable
  logging size 600
  hidekeys
username cisco privilege 15 secret 4 gen5RuvupsY2P477INMgE6BCBGVDoKq6c84oXARc2vk
controller T1 0/2/0
pri-group timeslots 1-24
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id FastEthernet0/0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
no isdn outgoing ie redirecting-number
trunk-group ALL_T1E1
no cdp enable
interface Dot11Radio0/5/0
no ip address
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 2
interface Vlan4
no ip address
bridge-group 4
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 10.1.1.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI2
ip address 10.1.2.1 255.255.254.0
ip nat inside
interface BVI4
ip address 10.1.4.1 255.255.255.0
ip nat inside
interface BVI100
ip address 10.1.100.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.100.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit 10.1.2.0 0.0.1.255
access-list 1 permit 10.1.4.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.100.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.100.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.100.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.100.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.100.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 4 protocol ieee
bridge 4 route ip
bridge 100 route ip
voice-port 0/0/0
station-id number 401
caller-id enable
voice-port 0/0/1
station-id number 402
caller-id enable
voice-port 0/0/2
station-id number 403
caller-id enable
voice-port 0/0/3
station-id number 404
caller-id enable
voice-port 0/2/0:23
bearer-cap Speech
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 399
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.100.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 pots
incoming called-number ^AAAA$
direct-inward-dial
port 0/2/0:23
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
destination-pattern 5126009842$
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3000 pots
description PRI1
translation-profile incoming PRI1_Called_5
incoming called-number 5126009844
direct-inward-dial
port 0/2/0:23
dial-peer voice 3001 pots
description PRI0-OP
translation-profile incoming PRI0-OP_Called_6
incoming called-number 5126009843
direct-inward-dial
port 0/2/0:23
dial-peer voice 3002 pots
description PRI2-OP
translation-profile incoming PRI2-OP_Called_7
incoming called-number 512600984[5-9]
direct-inward-dial
port 0/2/0:23
dial-peer voice 3003 pots
description PRI2-OP
translation-profile incoming PRI2-OP_Called_8
incoming called-number 512600985.
direct-inward-dial
port 0/2/0:23
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*North American-7-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_T1E1
corlist outgoing call-local
description **CCA*North American-7-Digit*7-Digit Local**
preference 3
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_T1E1
description **CCA*North American-7-Digit*Service Numbers**
preference 3
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_T1E1
corlist outgoing call-national
description **CCA*North American-7-Digit*Long Distance**
preference 3
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_T1E1
corlist outgoing call-international
description **CCA*North American-7-Digit*International**
preference 3
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_T1E1
corlist outgoing call-toll-free
description **CCA*North American-7-Digit*Toll-Free**
preference 3
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.100.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Cisco Small Business
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 8
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$xQde$4YoiP0kqbyF8eEtFb8R87/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Sep 13 2012 10:30:03
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  297  dual-line
number 203 no-reg primary
label 203
description Johnny Celey
name Johnny Celey
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  5
device-security-mode none
mac-address CCEF.485E.5D24
ephone-template 16
max-calls-per-button 2
username "jceley" password 123456
type 504G
button  1:297
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (1). Thu Sep 13 10:14:13 CDT 2012^^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
I have pasted the config and I am still not able to ping between vlans.
Hi David,
Looking at your configuration I’m guessing that all of your interfaces are showing up and up.  You can verify this by running “sho ip int brief".
If all of the interfaces are showing up and up there may be a configuration issue on the switch.  Is the SG300 in layer 2 or 3 mode?  If you’re in layer 3 mode verify your routing statements and that the VLAN's are active.  If you’re in layer 2 verify the trunk configuration going to the switch.
Let me know if this does not work for you.
Thank you,
Jason Nickle
