Showing results forĀ
Search instead forĀ
Did you mean:Ā
Intercom on UC560
syed_quadri
Hi Guys
Has anyone tried configuring Intercom  on UC560 using  CCA.
Is there any document I can read on how intercom works and its features.
Cheers
jbattist
Syed,
     If, in CCA, you go to the top menu bar; Help> Contents> View PDF, the CCA Administration Guide will open and you would be able to see the features and configurations CCA is capable of performing.  Or here is the link to the admin guide:
http://www.cisco.com/c/en/us/support/cloud-systems-management/configuration-assistant-cca/products-maintenance-guides-list.html
Hope this helps.
James Battisti
Arthur Lock
I used a Valcom system with mine. You assign an extension to the valcom controller and users dial that extension to access the intercom.  You can set up multiple extension for paging groups.
