Intermittent Caller ID on fxo port in UK on UC320
Paul Williamson
Beginner
Beginner
Is anyone else experiencing intermittent issues with caller id via the fxo port?  I'm running firmware version 2.3.1(14).
After rebooting the UC320 the first call received will display the correct caller id but any call received thereafter will only display as being from "fxo1".  Reboot the 320 and again, the first call received will again display the correct caller id but thereafter back to fxo1.
I've run the FXO impedance matching tool and inserted the correct values from the test but this is still occuring.  As far as I recall it was fine before I installed the release candidate.  Caller ID from the SIP trunks is fine.  Anyone else having similar problems or any suggestions to fix this?
Paul.
16 REPLIES 16
Jack Germanos
Beginner
Beginner
I am getting the same problem after upgrading to 2.3.1, it was showing calls from FXO at random.... I have rebooted and still happening
Well that's two of us then!  Are you in the UK Jack?
Any others experiencing problems?
Jack Germanos
Beginner
Beginner
I'm in Australia
Paul (and/or Jack),
Thanks for you question on the support community on this issue.
Couple questions if I may...
1) Was the fxo caller id working before upgrading to 2.3.1(14) and after upgrade it stopped presenting the caller id after the first call?
2) If a previous version did present the caller id correctly can you confirm what version?
3) Please open a support case with Cisco Small Business Support Center:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
There are additional fxo debug tools in firmware version 2.3.1(14).  The support team can request the correct syslog settings to help identify the caller-id issue.
Randy
Thanks for your reply Randy,
in answer to your questions:
1)  Yes it worked correctly prior to the upgrade to 2.3.1(14).
2) The previous version that worked correctly was 2.2.2
3) I'm opening a case now.
Thanks again.
Paul.
Case opened with support centre - I'll let you know what happens.
Just to update - Fabulous service from Cisco with this problem - I received a pmf file today from them which has fixed this problem.
Thank you very much guys - I know in other messages I've complained about the length of time it takes for things to get done, specifically, new features at Cisco but absolutely no such complaint when it comes to fixing an issue with a supported feature.
Wonderful service guys.
Paul.
That's great - I was seriously considering reverting to the previous firmware version.
So how can a mere user like me get this pmf file? It's not on the list of published pmf files yet?
Clive
Hmm... Good question, if you let me have your email address I could email it to you or maybe someone from Cisco could pick this up and help Clive and anyone else with this problem by giving them access to the file?  Tobi Asonibare at Cisco emailed me the pmf file.
Extract from Tobi's email:
"The PMF changes the call id method from ETSI FSK with PR (UK) to "ETSI DTMF with PR" and we've had a TME test it to be working in the UK."
So I'm assuming this may be of help to people only in the UK.
Let me know if I can help.
Paul.
chidcp999
Beginner
Beginner
I have the same issue in the UK with Callier ID no longer working for the fxo line.
These firmware updates - when they eventually turn up, see to be half a step forward and one back!
Not impressed with Cisco's response speed when it comes to updates and fixes for this box!
Monday was a holiday in the U.S.  We were waiting for feedback that the PMF worked before making it a general release.  We'll work on gettting it published  on the PMF page ASAP.
Chris
The published PMF files have been updated and is documented here:
https://supportforums.cisco.com/docs/DOC-16301
The PMF for the UK caller ID Method is
Caller_ID_Method
5N/A
Allow setting of ETSI DTMF With PR Caller ID Method on UC320W.
(Resolves some Call Id issues in UK).
Randy
We are getting a system crash also.  Call comes in without Caller ID. The call then breaks up and UC reboots.
I have just applied the PMF....fingers crossed!
Hi Tim,
Are you by chance using BRI circuits for PSTN access?  If so, you will want to upgrade to the 2.3.1 Release Candidate firmware found on this community.
Chris
