Is it possible to have the phones ring with a different ring tone for Internal calls?
I have tried googling but have come up with nothing.
If you have multiple line buttons you can have different extensions for external and internal calls. Then you can setup the ring parameters for the button to ring differently.
You may check out my post here:
https://supportforums.cisco.com/message/3939460#3939460
I see.
But no other easy way?
It is a different tone.
Listen carefully. Two short tones, or one longer tone.
