05-05-2013 07:53 AM - edited 03-21-2019 07:19 AM
HI all,
I am facing call dropping for international call . When I starts dialing 900 it is giving bust tome and disconnecting.
Confirming here call restriction for extensions are international and FXo line having international capability.
Please see the debug section on the time of call generate from extension 210
000372: May 5 14:11:23.899: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=210, Called Number=, Voice-Interface=0x884EFF70,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
000373: May 5 14:11:23.899: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20011
000374: May 5 14:11:24.383: //-1/809E8585805A/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9, Peer Info Type=DIALPEER_INFO_SPEECH
000375: May 5 14:11:24.383: //-1/809E8585805A/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9
000376: May 5 14:11:24.387: //-1/809E8585805A/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
000377: May 5 14:11:24.387: //-1/809E8585805A/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
000378: May 5 14:11:25.183: //-1/809E8585805A/DPM/dpMatchPeersCore:
Calling Number=, Called Number=90, Peer Info Type=DIALPEER_INFO_SPEECH
000379: May 5 14:11:25.183: //-1/809E8585805A/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=90
000380: May 5 14:11:25.183: //-1/809E8585805A/DPM/dpMatchPeersCore:
000381: May 5 14:11:25.183: //-1/809E8585805A/DPM/dpMatchPeersMoreArg:
000382: May 5 14:11:25.399: //-1/809E8585805A/DPM/dpMatchPeersCore:
Calling Number=, Called Number=900, Peer Info Type=DIALPEER_INFO_SPEECH
000383: May 5 14:11:25.399: //-1/809E8585805A/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=900
000384: May 5 14:11:25.403: //-1/809E8585805A/DPM/dpMatchPeersCore:
000385: May 5 14:11:25.403: //-1/809E8585805A/DPM/dpMatchPeersMoreArg:
000386: May 5 14:11:25.775: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 809E8585B4C411E2805ABD0D69AAB73F, SetupTime 19:11:23.905 PST Sun May 5 2013, PeerAddress 210, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 19:11:25.775 PST Sun May 5 2013, DisconnectTime 19:11:25.775 PST Sun May 5 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
000387: May 5 14:11:25.775: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:05/05/2013 19:11:23.903,cgn:210,cdn:,frs:0,fid:35,fcid:809E8585B4C411E2805ABD0D69AAB73F,legID:1D,bguid:809E8585B4C411E2805ABD0D69AAB73F
000388: May 5 14:11:25.779: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=210$, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
000389: May 5 14:11:25.779: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
this is my dial peer configuration for international dialing..
dial-peer voice 69 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*UAE*International**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 900T
forward-digits all
no sip-register
Please suggest me the reason .....
Rinchuraj
05-05-2013 01:40 PM
Try
no translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
no preference 5
destination-pattern 9[0][0][1-9]....T
no forward-digits all
05-15-2013 06:22 AM
Hi Paolo,
I made this changes, but no scope .
I tried by change the prefix with 8 and assigned outgoing translation profile ... Hurreyyy the calls are going....
trunkgroup ALL_FXO
preference 5
destination-pattern 8[0][0][1-9]....T
forward-digits all
no sip-registe
voice translation-rule 1112
rule 1 /^9/ //
rule 1 /^8/ //
translate called 1112
05-15-2013 06:24 AM
Can u help me by poviding with the cptone for Lebanon.
Rinchuraj
05-15-2013 07:11 AM
You need to remove "forward digits all". Also check that in many country you cna configure so to not need an acces digit, that makes everything easier.
