IP Communicator doesn't change language
Support Albakom
Level 3
Level 3
use an IP Communicator 7.0.5 at Windows 7 64 Bit connected to a UC520
All works fine. Only the language of the CIPC is still english. I changed the locales via CCA 2.2.6 successfully to German. All the other phones are german, the CIPC not.
I created CNF-Files more than one time, nothing changed.
The UC520 is at the 8.0.5 pack.
What can I do?
Thank you for your time today in our webex session, basically the issue was reachability to the TFTP (sourced from lo0)
I am glad you have it working now
9 Replies 9
vcappucc
Hello
I have just tried this,
i have downloaded the CME-locale-de_DE-7.0.1.1.tar that is available on this link https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=UC500
and my CIPC is on german now
this is what i did to make it work
art1#mkdir DE
Create directory filename [DE]?
Created dir flash:DE
Cart1#
Cart1#archive tar /xtract ftp://192.168.100.111/CME-locale-de_DE-7.0.1.1.tar f$
Loading CME-locale-de_DE-7.0.1.1.tar
extracting 7921-dictionary.xml (59216 bytes)!
extracting 7921-font.dat (137616 bytes)
extracting 7921-kate.utf-8.xml (1863 bytes)
extracting 7921-kate.xml (1806 bytes)
extracting be-sccp.jar (61838 bytes)!
extracting g3-tones.xml (1386 bytes)
extracting gp-sccp.jar (74885 bytes)
extracting ipc-sccp.jar (61913 bytes)
extracting mk-sccp.jar (61653 bytes)
extracting tc-sccp.jar (71712 bytes)!
extracting td-sccp.jar (61913 bytes)
extracting CME-locale-de_DE-German-7.0.1.1.tar.cfg (225 bytes)
[OK - 614400/4096 bytes]
Cart1#deb tftp event
TFTP Event debugging is on
Cart1#
Cart1#
Cart1#conf ter
Enter configuration commands, one per line.  End with CNTL/Z.
Cart1(config)#tele
Cart1(config)#telephony-service
Cart1(config-telephony)#network-locale DE
Updating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
CNF files update complete
Cart1(config-telephony)#user-locale DE
Updating CNF files
CNF files updating complete
Cart1(config-telephony)#^Z
Cart1#
in the tftp logs  the phone seems to be looking for 000698: TFTP: Looking for German_Germany/ipc-sccp.jar
and we have that file from the tar file
so
en
conf ter
tftp-server flash:/DE/ipc-sccp.jar alias German_Germany/ipc-sccp.jar
end
and restart your CIPC.
i will try on my copy of CCA 3.0 - and will let you
thanks
Victor.-
doing this with TFTp-Server and so on.
the ipc-sccp.jar was already present in flash.
I reset the communicator and this is the output of debugging tftp:
000105: Dec  9 09:13:22.699: %IPPHONE-6-UNREGISTER_NORMAL: ephone-7:SEP0000E8000959 IP:192.168.10.20 Socket:3 DeviceType:Phone has unregistered normally.
000106: Dec  9 09:13:22.847: TFTP: Looking for CTLSEP0000E8000959.tlv
000107: Dec  9 09:13:26.847: TFTP: Looking for SEP0000E8000959.cnf.xml
000108: Dec  9 09:13:26.851: TFTP: Opened flash:/its/XMLDefaultCIPC.cnf.xml, fd 14, size 1353 for process 181
000109: Dec  9 09:13:31.855: TFTP: Looking for Communicator/LdapDirectories.xml
000110: Dec  9 09:13:36.863: TFTP: Looking for Communicator/LdapDialingRules.xml
000111: Dec  9 09:13:40.891: TFTP: Looking for CTLSEP0000E8000959.tlv
000112: Dec  9 09:13:44.895: TFTP: Looking for CTLSEP0000E8000959.tlv
000113: Dec  9 09:13:49.747: TFTP: Looking for CTLSEP0000E8000959.tlv
000114: Dec  9 09:13:51.859: TFTP: Finished flash:/its/XMLDefaultCIPC.cnf.xml, time 00:00:25 for process 181
000115: Dec  9 09:13:53.747: TFTP: Looking for CTLSEP0000E8000959.tlv
000116: Dec  9 09:13:57.751: TFTP: Looking for CTLSEP0000E8000959.tlv
000117: Dec  9 09:14:01.755: TFTP: Looking for CTLSEP0000E8000959.tlv
000118: Dec  9 09:14:05.755: TFTP: Looking for SEP0000E8000959.cnf.xml
000119: Dec  9 09:14:05.759: TFTP: Opened flash:/its/XMLDefaultCIPC.cnf.xml, fd 14, size 1353 for process 181
000120: Dec  9 09:14:09.975: %IPPHONE-6-REG_ALARM: 20: Name=SEP0000E8000959 Load= 7.0.5.0 Last=Phone-Keypad
000121: Dec  9 09:14:09.975: %IPPHONE-6-REGISTER: ephone-7:SEP0000E8000959 IP:192.168.10.20 Socket:3 DeviceType:Phone has registered.
No looking for  ipc-sccp.jar in the debug.
In the XMLDefaultCIPC.cnf.xml the locales are right configured with Germ,an_Germany.
Can you please send your show tech voice and your contact information to vcappucc@cisco.com, i will call you and see this.
is sent
Hello Sir, I did not got the email, for some reasson i can not find it on my inbox, please send me a PM or resend please the email.
Thank you
I resent the mail.
Thanks also for your help. I found it strange that the CIPC
needs another IP for TFTP to get the locals. I never get this behaviour in earlier UC installations.
yes, its works with spanish....
download CME-locale-es_ES-Spanish-8.6.2.4
extarct in the flash or directory
and ..
#config t
#tftp-server flash:ipc-sccp.jar alias Spanish_Spain/ipc-sccp.jar
and reload your cipc !!!....
