IP Communicator Not Working With UC_540
gbouck
Beginner
Beginner
Hello All,
I am running Cisco IP Communicator with a UC_540.  I have configured the UC_540 for the IPC Extension with the following specs.
MAC 5427.1E0A.0810 - MAC of Network Adapter on the Laptop
Phone Type - CIPC
Expansion Module - None
Preferred Codec - g711ulaw
Missed Calls - Exclude Overlay Button
First Name - BDCRemote
Last Name - H
UserID BDCRemoteH
Password - 123456
The Issue:
When I open IP Communicator, the application appears to register successfully, but the time is 5hrs ahead and the extension does not appear.   We have been using IP Commuicator off and on for about 14 months.  I have never seen this issue.
Your thoughts and wisdome are extremely appreciated!
JP
1 REPLY 1
Alexander Maroukian
Rising star
Rising star
Hello Gabe,
Please verify if the phone registers successfully.
In CCA Monitor -> Telephony -> Phones and extensions  - the status should be registered.
Also you may set the TFTP to 10.1.10.2 (if this is the Loopback 0 address and it is set as tftp source)in the options of the CIPC.
HTH,
Alex
*Please rate helpful posts
