Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
524
Highlighted
Beginner
Jabber for iPhone - calling phone's contacts
I configured Jabber on a UC500 for some iPhone users. Jabber works pretty well, but numbers from the phones' contacts cannot be called directly, since a additional 0 before the actual number is required to dial outside the customers network.
Is there a way for automaticaly adding these zeroes to numbers called by Jabber extensions, while internal numbers can still be called?
I've looked into translation-profiles and dial-peers but didn't find anything suitable for my problem...
Kind regards,
Rainhard
4 REPLIES 4
Highlighted
Beginner
here is a post of similar style that i have already started...
https://supportforums.cisco.com/message/3886100#3886100
Hopefully they will fix this in a release of Jabber!
UC540 system with 8.6.1 Software Pack
UC540 system with 8.6.2 Software Pack
Highlighted
Beginner
I found a way to "fix" this problem! I configured a seperate COR list and dial-peer for the Jabber users without any translation of the called number. They can now directly dial their phone's contacts.
Kind regards
Rainhard
Highlighted
Beginner
This is good news! Do you mind outlining the steps you did to do this
Highlighted
Beginner
Here's what my configuration looks like:
! COR config
dial-peer cor custom
  name JABBER
exit
dial-peer cor list call-JABBER
  member JABBER
exit
! Dial-peer for outgoing jabber calls
dial-peer voice pots
  corlist outgoing call-JABBER
exit
! For every jabber phone
voice register pool
  cor incoming call-JABBER default
exit
Kind regards,
Rainhard
