Jabber
myles
I know it's not officially supported yet, until we get 8.6 (fingers crossed that it's actually next month!), but having played around with the Jabber clients, does anyone have any idea what the Device ID should be?
Maybe someone using the beta in a lab?
paolo bevilacqua
The configuration for iPhone SIP client is detailed in the CME Administrator Guide, since about one year already.
The beta is also out already, and Jabber appears to work fine.
David Trad
Hi Myles,
If I am not mistaken this will be the extension number, but it has been a while since I last played with Jabber so I might be wrong...
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
