Keep previous configuration on phone
Joao Oliveira
Hi!
When you are dealing with the configuration files that are going to be read by the phones, sometimes it is usefull that some parameters keep the same values as before, in a way that users can change some parameters on the phone GUI without the profile rule overwritting users values.
I have seen in a configuration file something like this:
  <SPA525-SSID ua="na">~</SPA525-SSID>
  <SPA525-Encryption-type ua="na">~</SPA525-Encryption-type>
  <SPA525-Encryption-key ua="na">~</SPA525-Encryption-key>
Does the tilde here works as a "keep previous value"?
Joao
nseto
Level 6
Level 6
For parameters that are to be changed by the end user, those parameters should be removed from the config file.  Just have parameters in the config file that you must control.
