Latest 525G Firmware 7.4.4 breaks video cam streaming
Sven.WieseSolty
After installing the latest firmware 7.4.4 for a SPA525G the streaming of a cisco web cam (PVC2300) fails! With firmware 7.4.3 everthing works as described in the documentation. On the phone webpage for the web cam entrys the password textfield is missing.
Sven
6 Replies 6
nseto
Level 6
Level 6
I just tested 7.4.4 with the wvc2300 1.1.1.4 and it works fine.
The phone's User/Camera Profile contained all the parameters needed to setup the camera.  I do have the access password field.  For your phone, this field is missing?
Used the following link as reference
https://supportforums.cisco.com/docs/DOC-9806
Sven.WieseSolty
Thx for reply. I'll give 7.4.4 a second try. We had an exhibition, so it was nessesary that everthing is working... I will post a screenshot to explain the problem. Thx for the doc, but that was exactly the doc we used.
Sven
Sven,
Perhaps pages 60 through 64 of https://www.myciscocommunity.com/docs/DOC-11915 will be of use.
I wrote it using 7.4.3, but this section should be the same for 7.4.4.
Patrick
I'm having the same issues, i've upgraded to 7.4.4 and there is no password field.
The field only shows when logged in as admin/advanced.  The password field doesn't display when user/basic, user/advanced or admin/basic.
Ah! perfect - Thanks.
