LDAPS for SPA5xx or 88xx
jakub.zima
is there any possibility how to use LDAPS or LDAP over TLS with SPA5xx or 88xx phones?
The only method I can use is a digest MD5.
But I need to secure also data in LDAP session (not only credentials).
I'm using the latest FW.
Best regards,
Jakub Zima
thanks for the reply.
I just found that in the latest FW there is finally possible to use LDAPs for 88xx series.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/MPP/8800/english/administration/p881_b_8800-mpp-ag/p881_b_8800-mpp-ag-11_chapter_010000.html
LDAPs is also available for 68xx.
The only trouble which I found is that Cisco signed certificate is needed on LDAP server.
CSR can be signed here: https://webapps.cisco.com/software/edos/home#
Dan Lukes
Its not possible as far as I know.
Pokud jsem neco zasadniho neprehledl ...
Note the service has been moved to https://software.cisco.com/software/cda/home
