Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
444
Highlighted
Beginner
Login problem after 2.1.4(3) update
Hi:
following UC320w instructions I updated firmware to V2.1.4(3). Te update went throughg just fine but when I tried to relog into the system it kept telling me that user and/or password was not correct.
I reset system to factory defoults and went through the whole configuration from scrath and everything was smooth, i loged out and when trying to log in again same problem the usar and password I introduced during config is no good AGAIN, I tried cisco/cisco also but no luck.
Is there any way i can access without the need to reset it AGAIN to factory??. Is this a known issue wit fw version??, shoul I downgrade fw??
2 REPLIES 2
Highlighted
Beginner
Hello Alejandro,
I work in the Cisco Small Business Support in Europe.
Can you please confirm that the Cisco Small Business Support was able to solve your issue.
Friedrich
Highlighted
Beginner
Re: Login problem after 2.1.4(3) update
Yes it is fixed, thans a lot.
2012/1/17 fscharz
Home <> Re: Login
problem after 2.1.4(3) update created by Friedrich Scharz<>in
UC300 Series - View the full discussion<>
