My customer lost all but two ringtones on the ip phones after we upgraded to 7.0.2. Any ideas of how to get all of the ringtones back to the ip phones?
Larry,
In my investigation I have seen two cases where the RingList.xml file cannot be used and my phone shows only Chirp1 & Chirp 2 rings available. First RingList file is corrupt, after I went to the phone GUI and selected (User Preferences -> Rings -> Line 1 default ring) there I see only the Chirp ring tones and a message that the RingList.xml file is bad. I used a tftp server, like tftp desktop or pumpkin, to manually tftp the RingList.xml and DistinctiveRingList.xml file to the UC520. Please be sure CCA is closed before you start the tftp server as CCA has its own tftp server and will interfere. The second case I found was using a customized RingList.xml where an error in the syntax created a problem and again only the Chirp ring tones were seen.
Please manually tftp the RingList.xml and DistinctiveRingList.xml files and reset the phones. I loaded the exact file you attached earlier with no problems so I expect this is the case where the file is corrupt in flash.
To see what files are being hit by tftp when the phone is reset or when attempting to change the ring tone run the command #debug tftp packets
Just dont forget to #undebug all when your done.
you should see a log similar to this:
Feb 26 17:31:28.743: TFTP: Looking for ringlist.xml
Feb 26 17:31:28.855: TFTP: Opened flash:RingList.xml, fd 10, size 3001 for process 172
Douglas Smith
in my post here I say that I am runnign the new uc520 pack with the new ios, yes I am having the issues even with the new version of software.
larry
Eivind,
You are correct, the config was missing the alias on all the loads and the ringlists as well.
Thanks for your input,
Douglas Smith
I am unclear, did you get this to work?
What was your fix?
Spollock,
We did get the ringtones to work by making the tftp-server lines look like the fllowing: tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
Douglas Smith
Doug, many thanks fo course.
My config looks like this:
ftp-server flash:CP7902080001SCCP051117A.sbin
tftp-server flash:apps11.1-1-2-26.sbn
tftp-server flash:cnu11.3-1-2-26.sbn
tftp-server flash:cvm11sccp.8-0-2-25.sbn
tftp-server flash:dsp11.1-1-2-26.sbn
tftp-server flash:jar11sccp.8-0-2-25.sbn
tftp-server flash:SCCP11.8-0-3S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:S00104000100.sbn
tftp-server flash:cmterm_7936.3-3-5-0.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sbn
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.bin
tftp-server flash:cmterm-7941-7961-sccp.7.0.3.tar
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:apps31.8-1-0-89.sbn
tftp-server flash:cnu31.8-1-0-89.sbn
tftp-server flash:cvm31sccp.8-1-0-90.sbn
tftp-server flash:dsp31.8-1-0-89.sbn
tftp-server flash:jar31sccp.8-1-0-90.sbn
tftp-server flash:SCCP31.8-1-1SR2S.loads
tftp-server flash:term31.default.loads
tftp-server flash:APPS-1.0.1.SBN
tftp-server flash:CP7921G-1.0.1.LOADS
tftp-server flash:GUI-1.0.1.SBN
tftp-server flash:SYS-1.0.1.SBN
Are you saying add an alias command for every line?
Also, none of the ringtones are listed. Should I add the ringtone files, one per line as well?
what about the .XML files?
thanks again
The file locations on flash need to coordinate with what the phones are looking for. If a phone is looking RingList.xml, and the file is in /phones/ringtones/RingList.xml, you will need to alias it. The tftp server command says what file to serve, and the location of that file. If the phone is expecting the file in a different location on flash, you alias it.
Also, all of your ringtones and the ring list file need to have tftp server commands. That is likely your problem. Upload a show run and a dir flash: (as attachments) and we can get this solved quickly.
show run and dir flash attached
Cowacella#more RingList.xml
Cowacella#more DistinctiveRingList.xml
Cowacella#
You are missing several TFTP server commands.
tftp-server flash:RingList.xml
tftp-server flash:DistinctiveRingList.xml
You will also need similar commands for the .raw files.
tftp-server flash:Analog1.raw
tftp-server flash:Bass.raw
etc etc
That should fix your problem.
Steve you say:
you are missing several TFTP server commands.
etc etc
You would only need to alias if the files were located somewhere else on flash.
Say you have a phone load name called phoneload.sbin. And you put it on your flash at flash:/phones/myphoneloads/phoneload.sbin.
When the phone looks for the file, it doesn't look in that directory, it just looks for the file on flash (flash:/phoneload.sbin).
In that case, you would use the alias command, because the phone is looking for the file in a different location. It is only when the phone is looking for a file in a different location that you need to use the alias command. For the case that I presented, here would be the tftp server command.
tftp-server flash:/phones/myphoneloads/phoneload.sbin alias phoneload.sbin
