I know that internally we can have a max of 8 fxs ports (when using the expansion), but lets say I wanted 20 of them, is there a solution for that?
Thanks!
Chris
You could use a VG224. It is kind of expensive, but there are other options available as well, like a SPA8000.
It is a CLI only config.
Steve,
Thanks for the quick response.
Has anyone used multiple SPA's on their UC500?
Thanks!
Chris
I would definitely recommend the VG224. The CLI is quite easy to use and the 24 ports can be configured directly though CUCM.
