MCS 7825-I4 and BE3000 connectivity
lnoriega64
Is it possible to connect a 7825-I4 Call Manger and a BE3000 through SIP trunks?
Luis Noriega
If the BE3K & CUCM are in the same LAN, you should not require a CUBE. If they are in different locations, you can use CUBE for things like CAC.
There are  dial plan changes required for calls to route over SIP trunk between the two systems. The application note will cover that and other configuration items on  CUCM.
sanjsinh
It is not officially supported yet.
This is something which we are targeting for next release where we will publish an Application Note to help with the integration.
Thank you Sanjay.
It is not possible trough 2800 routers and CUBE?
Luis Noriega
