Migration to BE 6000
fuhrersk8
Level 3
Level 3
                   Hello guys!
     When migrating an exisiting CallManager 4 and Unity 4 to a new BE 6000 system, in terms of the exisitng users and voicemail licenses, does it is necessary to add the R-UNIFIED-CMBE6K part number equal to the quantity of users to be migrated in addition to the UWL-UPG-CMAPPS-BE part number (also equal to the quantity of migrating users) already added to the order CMBE6K-UWL starter bundle?
Or, only with the UWL-UPG-CMAPPS-BE part number selected in the CMBE6K-UWL starter bundle is sufficient to migrate the exisiting users and voicemails?
In the BE 6000 Oredeing Guide gives the impression as if it is needed to order both part numbers in order to migrate the exisiting users.
Thanks in advanced guys!
1. Start with Top Level product number CMBE6K-UWL
2. Select the Cisco Business Edition 6000 Workspace Bundle. The Workspace Bundle includes all the UCS server and client software for the applications included under Cisco Unified Workspace Licensing Business Edition, the UCS C220 [sic: it should say C200] server hardware for deploying Cisco Business Edition 6000, and licenses for the first 50 or 100 users. 1. Start with Top Level product number CMBE6K-UWL
If this answer was satisfactory for you, please mark the question as Answered.
Thank you
ronpatel
Level 8
Level 8
I would advice you to please contact PH team at cisco.com/go/ph and open case there. Partner helpline team will be able to give accurate information. Since you are Cisco Partner you can raise this case free.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Thanks for the advice Ron!
Thank you
