01-04-2011 12:08 PM - edited 03-21-2019 03:29 AM
Well .. the title actually says it all. When playing MoH in an internal-internal conversation it lags/stutters when you execute a copy run start from the command line. When this is done with an internal-external conversation there is a small hickup.. not nearly as bad as an internal-internal call.
The running config is 30499 bytes in size.
The MoH problem occurs if the complete MoH file is cached and not cached (show ephone moh).
This is not a major bug but .. kind of annoying. Any thoughts?
Solved! Go to Solution.
01-04-2011 02:53 PM
Interesting idea.. I have never seen this done before. On the Catalyst switches you can apply CoPP, but that only deals with packet flow, not processes initiated by the user via CLI. Personally, I wouldn't worry about since I like to make changes during downtime. Besides how often do you save your config throughout the day?
01-04-2011 12:24 PM
Can we get some more information about the box?
1. What flavor of UC500 is it?
2. What IOS are you running?
3. Is MOH running from a wave file or from the external MOH Port.
Brian
01-04-2011 12:33 PM
My first post is indeed low on information. It's the UC520W-8U-2BRI-K9 but our UC540 has the same problem. This UC520 is running uc500-advipservicesk9-mz.150-1.XA3a. MoH is running from an .au file, the UC520 has a custom .au file and the UC540 has the default .au file.
Bryan
01-04-2011 12:51 PM
Copy run start uses CPU resources and so does MOH. The commands and debugs you type in CLI shoot to the top of the list when it comes to CPU processes. In CCA go to Troubleshoot\IOS Exec Commands and type show processes to verify.
01-04-2011 02:26 PM
It has to do with cpu utilization indeed. Is it possible to limit the cpu usage of the copy run start proces so the MoH doesn't lag? It isn't a major issue but it wouldn't be a bad idea to fix it. It's all about how the customer experiences the UC500.
01-04-2011 02:53 PM
01-05-2011 05:21 AM
I'll mark that as the correct answer. You're right that it isn't a dealbreaker..! But mentioning it so other people have a heads up is the least I can do
