Monitor Voice utilization on UC500
Hi:
How can I monitor (count) number of times user tries to make a call and doesn't succed
I have a client who has a 2-UC500 BRI connected to PSTN.
- How do I monitor  (count) the number of times a user tries to call and doesn't succeed because of all ISDN channels are busy?
TIA
FRancisco
1 REPLY 1
David Trad
Rising star
Rising star
Hi Francisco,
The UC-500 has a call accounting feature which you can enable it via CCA (Please refer to image)
You will need an FTP server to which you can upload the information to, and this will give you CDR (Call Distribution Records) and you can then pass them into what ever system you want or read it as a raw file, either one can work quite well.
Surprisingly this to me seems to a very much unused feature although it holds a lot of usefull information in it
Hope this helps you out...
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
