10-09-2012 06:22 AM - edited 03-21-2019 06:24 AM
I am looking for possible solutions for adding an additional FXO line to a UC540 as well. Mine already has the additional VIC2-4FXO module and all FXO ports are used. From reading the Manuals, Release Notes, and Forums, it sounds like the 8800 will only support additional FXS ports. I have not found a solid answer as to why that is. It seems like it would be a hardware/platform overload issue for the UC540 to support more than 8 FXO lines. Is this assumption accurate or is there something we can do about it?
10-09-2012 08:52 AM
That is correct. For more than 8 circuits, upgrade to ISDN PR. It will be cost convenient, and will give much bettter working and features.
10-10-2012 05:07 AM
I appreciate your prompt response. I know what ISDN BRI and PRI signaling is. However I am not sure I understand your response. Could you please elaborate on what you mean by "upgrade to ISDN PR".
10-10-2012 10:24 AM
I mean ISDN PRI, that you can ask your telco about.
Or even a SIP trunk would be advantegeous instead of many analog circuits.
10-10-2012 10:53 AM
A sip trunk would definitely be a better solution than 8 analogue lines but depends on the internet connection the client can get I guess.
