09-30-2011 10:03 PM - edited 03-21-2019 04:44 AM
I've recently moved away from SIP trunks feeding our UC520 over to PRI. Unit originally did not have a PRI card which was installed and additional configs were added to get it working.
One problem we're having is the CFwdAll feature to external numbers.
For example: user sets CFwdAll on his phone to outside number 91xxxxxxxxxx. Caller from outside dials this user's direct number and it rings once and then gets a slow busy. Call never connects. (This used to work when we were on SIP)
Doing a CFwdAll to an internal number works fine. Outside caller is fwded to another inside extension with no issue.
Can anyone help?
Thanks! J4
I have attached config and few debugs.
10-03-2011 04:52 PM
any ideas will be appreciated! thanks
03-25-2015 08:23 PM
I have this same exact problem, and can't get a straight solution for it. were you able to figure this out??
~ Cuevas
