Moved from SIP to PRI. Having issues with Call Forward
J4solutions
Beginner
Beginner
I've recently moved away from SIP trunks feeding our UC520 over to PRI.  Unit originally did not have a PRI card which was installed and additional configs were added to get it working.
One problem we're having is the CFwdAll feature to external numbers.
For example:  user sets CFwdAll on his phone to outside number 91xxxxxxxxxx.  Caller from outside dials this user's direct number and it rings once and then gets a slow busy.  Call never connects.  (This used to work when we were on SIP)
Doing a CFwdAll to an internal number works fine.  Outside caller is fwded to another inside extension with no issue.
0 REPLIES 0
