08-15-2010 04:01 PM - edited 03-21-2019 02:52 AM
We have a customer with two UC500s in a multiple site configuration. We are not using VPN - it is a MPLS configuration with a Windstream SIP trunk.
When a outside call comes in over the SIP trunk and a user transfers the call locally at that site, the user receiving the transferred call can see the caller ID from the original (outside) caller once the transfer is complete. However, if the user receiving the outside call transfers it to a user at the other site, the receiving user only sees the internal extension of the senders phone even when the transfer is completed.
Any thoughts on this?
Joe
Solved! Go to Solution.
09-02-2010 07:06 PM
Hi Joe,
Can you make sure that it's configured on both UC500's?
voice service voice
sip
update-callerid
Also make sure that you don't have "no remote-party-id" configured under sip-ua for both UC500's as well.
If it still doesn't work can you attach the 'show run' from both UC500's and include the 'debug ccsip message' output when you do the transfer operation?
-Anthony
08-17-2010 01:26 AM
Are you doing a blind or consult transfer?
Can you attach your 'show ver/run' output?
Anthony
08-27-2010 01:49 PM
08-29-2010 05:23 PM
Looks like you are configured for SIP for intersite dialing. Can you try adding-
voice service voice
sip
update-callerid
Anthony
08-31-2010 08:25 PM
Anthony,
I added this command. It did not make a difference.
Any other ideas?
Joe
09-02-2010 07:06 PM
Hi Joe,
voice service voice
sip
update-callerid
-Anthony
09-15-2010 06:34 PM
Anthony,
This appears to have fixed the problem. Thank you!
09-16-2010 08:30 AM
Good to hear!
Thanks for confirming.
-Anthony
