05-06-2010 09:15 AM - edited 03-21-2019 02:32 AM
Is the UC540 capable of handling 2 SIP trunk connections to 2 different providers? Thanks.
05-06-2010 09:34 AM
Not supported via CCA at this time - something we are looking to add in the next release. More info can be got on the below:
05-06-2010 09:36 AM
Is it supported via CLI at least? If not on the UC540, how about the UC560?
Audy Bautista
audy@rfa.com
Cell: 646-210-0935
Direct: 212-659-4833
05-06-2010 09:39 AM
Hi Andy
Maulik Shah answered your question with the following info;
05-06-2010 09:41 AM
Awesome, thank you!
The UC500 can have SIP trunks to different service providers which may be required in some cases for least cost routing etc. This is an optional Supplemental Feature that is not configured by CCA 2.2 but requires CLI expertise. This feature is supported on the UC500 software pack 8.0.0 or later - CLI configuration is at http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-multi-registrars.html .
09-15-2013 05:50 PM
I had a similar question to this.
Can I have two definitions (accounts) for the same ITSP (Engin) configured?
i.e. on a UC560 can I have two SIP trunks configured to Engin and route calls based on originating DN.
Before you ask why
I have multiple ISDN DID ranges for inbound calls.
My Engin SIP trunks are configured to SET the outbound caller-id to a particular number so return calls come back to reception. I need a second user group to caller-id with a different number when going outbound via SIP hence the second trunk.
