Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1078
TIMOTHY DAVIDSON
Beginner
Multisite dial-plan
Is there a way to NOT use Inter-site Dialing Prefix and Site Identifier's?  Each of my sites will have unique 4-digit extensions and forcing the users to dial extra digits just seems silly.
Thanx....
1 ACCEPTED SOLUTION
graeme
Beginner
It might not be the most elegant solution and requires a little bit of extra work.
But we setup
Site 1 Ext 200 - 299
Site 2 Ext 300 - 399
Site 3 Ext 400 - 499
(there are only a max of 30 users in any one site.)
So site dialing would be 81201 83401 etc
On each site we setup floatin extensions so say Site 1 had extension 301 a flowting extesion redirecting to 82301 and so on.
Requires a bit of extra work but then thats what trainees are for
3 REPLIES 3
John Platts
Enthusiast
Yes, it is actually possible to do so on the UC500 series. However, this kind of configuration is not yet supported in CCA Multisite Manager. I actually configured this feature on the UC520 before CCA had the Multisite Manager feature. CCA should support configuring site-to-site dialing without inter-site prefixes and site identifiers in the Multisite Manager.
graeme
Beginner
But we setup
Yes, that works, thanx.  I just wish there was a much simpler way to do it.  What a pain...
