Multisite Voice One Way Problem
mabucham7
    I have an issue with multisite using 2 UC520s, I have set it up using CCA for both Data and Voice which was straight forward, data seems to be working perfectly, while voice seems to be working only one way, meaning if I call from site 1 to site 2 its rings but then nothing, while if I call from site 2 to site 1, I can hear everything but they can’t hear me. i used the attached document to try and diagnose things or even match configuration with no luck, so can anyone help
15 Replies 15
johschaf
Level 4
Level 4
Could you please post the following(removing all public IPs, passwords, preshared keys, etc):
cypto map from both UCs
ACLs referenced in the crypto map
NAT and WAN ACLs
multisite dial-peers
voice service voip config
-john
Yes of course, hope i didnt miss anything:
Site 1:
Crypto Map IPv4 "multisite" 1 ipsec-isakmp
    Description: Site2
    Peer = xx.xx.xx.xx
        Extended IP access list 106
        access-list 106 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
    Current peer: xx.xx.xx.xx
    Security association lifetime: 4608000 kilobytes/3600 seconds
    Responder-Only (Y/N): N
    PFS (Y/N): N
    Transform sets={
        ESP-3DES-SHA:  { esp-3des esp-sha-hmac  } ,
    QOS pre-classification
    Interfaces using crypto map multisite:
        FastEthernet0/0
UC_520#show access-lists
Extended IP access list 100
    10 deny ip 192.168.0.0 0.0.0.255 any
    20 deny ip host 255.255.255.255 any
    30 deny ip 127.0.0.0 0.255.255.255 any
    40 permit ip any any
Extended IP access list 101
    10 permit udp any host 10.1.10.2 eq non500-isakmp
    20 permit udp any host 10.1.10.2 eq isakmp
    30 permit esp any host 10.1.10.2
    40 permit ahp any host 10.1.10.2
    50 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any (21023 matches)
    60 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
    70 deny ip 192.168.0.0 0.0.0.255 any (7 matches)
    80 deny ip 10.1.1.0 0.0.0.255 any (1336 matches)
    90 deny ip host 255.255.255.255 any
    100 deny ip 127.0.0.0 0.255.255.255 any
    110 permit ip any any (14650 matches)
Extended IP access list 102
    10 permit udp any host 192.168.0.101 eq non500-isakmp
    20 permit udp any host 192.168.0.101 eq isakmp
    30 permit esp any host 192.168.0.101
    40 permit ahp any host 192.168.0.101
    50 deny ip 10.1.10.0 0.0.0.3 any (7 matches)
    60 deny ip 10.1.1.0 0.0.0.255 any
    70 deny ip host 255.255.255.255 any
    80 deny ip 127.0.0.0 0.255.255.255 any
    90 permit ip any any (219560 matches)
Extended IP access list 103
    10 permit udp any host 10.1.1.1 eq non500-isakmp
    20 permit udp any host 10.1.1.1 eq isakmp
    30 permit esp any host 10.1.1.1
    40 permit ahp any host 10.1.1.1
    50 permit tcp 10.1.10.0 0.0.0.3 any eq 2000 (35688 matches)
    60 permit udp 10.1.10.0 0.0.0.3 any eq 2000
    70 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
    80 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any (1343 matches)
    90 deny ip 192.168.0.0 0.0.0.255 any
    100 deny ip host 255.255.255.255 any
    110 deny ip 127.0.0.0 0.255.255.255 any
    120 permit ip any any (4586927 matches)
Extended IP access list 104
    10 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
    20 permit udp host xx.xx.xx.xx host 192.168.1.64 eq non500-isakmp (8338 matches)
    30 permit udp host xx.xx.xx.xx host 192.168.1.64 eq isakmp (19 matches)
    40 permit esp host xx.xx.xx.xx host 192.168.1.64
    50 permit ahp host xx.xx.xx.xx host 192.168.1.64
    60 permit udp any host 192.168.1.64 eq non500-isakmp (2390 matches)
    70 permit udp any host 192.168.1.64 eq isakmp (2 matches)
    80 permit esp any host 192.168.1.64
    90 permit ahp any host 192.168.1.64
    100 deny ip 10.1.10.0 0.0.0.3 any
    110 deny ip 192.168.0.0 0.0.0.255 any
    120 deny ip 10.1.1.0 0.0.0.255 any
    130 permit udp any eq bootps any eq bootpc
    140 permit icmp any any echo-reply
    150 permit icmp any any time-exceeded
    160 permit icmp any any unreachable
    170 deny ip 10.0.0.0 0.255.255.255 any
    180 deny ip 172.16.0.0 0.15.255.255 any
    190 deny ip 192.168.0.0 0.0.255.255 any (968 matches)
    200 deny ip 127.0.0.0 0.255.255.255 any
    210 deny ip host 255.255.255.255 any
    220 deny ip any any
Extended IP access list 105
    10 permit ip 192.168.0.0 0.0.0.255 any
    10 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255 (20616 matches)
UC_520#show running-config
Building configuration...
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
sip
  registrar server expires max 600 min 60
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  call start slow
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
rule 2 /^7/ //
voice translation-rule 1113
rule 1 /^81\(...\)/ /\1/
voice translation-rule 1114
rule 1 /\(^...$\)/ /81\1/
voice translation-rule 2001
voice translation-rule 2002
rule 2 /^A/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile multisiteInbound
translate called 1113
voice translation-profile multisiteOutbound
translate calling 1114
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
no local-bypass
policy-map queue
class signaling
  bandwidth percent 5
class media
  priority percent 50
class class-default
  fair-queue
policy-map shape
class class-default
  shape average 1024000
  service-policy queue
gw-accounting syslog
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 1800
crypto isakmp key address 0.0.0.0 0.0.0.0
crypto map multisite 1 ipsec-isakmp
description Site2
set peer xx.xx.xx.xx
set transform-set ESP-3DES-SHA
match address 106
qos pre-classify
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
bandwidth 1024
ip address 192.168.1.64 255.255.255.0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
service-policy output shape
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
ip address 192.168.0.101 255.255.255.0
ip access-group 102 in
h323-gateway voip bind srcaddr 192.168.0.101
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ntp broadcast
ip local pool SDM_POOL_1 192.168.0.200 192.168.0.205
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
dial-peer voice 2100 voip
corlist incoming call-internal
description **CCA*INTERSITE inbound call to Site1
translation-profile incoming multisiteInbound
incoming called-number 81...
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to Site2
translation-profile outgoing multisiteOutbound
destination-pattern 82...
session target ipv4:192.168.2.200
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
Site 2:
UC_520#show crypto map
    Description: Site1
    Peer = xx.xx.xx.xx
        access-list 105 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
    PFS (Y/N): N
    Transform sets={
        FastEthernet0/0
    10 deny ip 192.168.2.0 0.0.0.255 any
    50 permit udp host 103.12.12.14 eq ntp host 10.1.10.2 eq ntp
    60 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any (11142 matches)
    70 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
    80 deny ip 192.168.2.0 0.0.0.255 any
    90 deny ip 192.168.3.0 0.0.0.255 any
    100 deny ip 10.1.1.0 0.0.0.255 any (147 matches)
    110 deny ip host 255.255.255.255 any
    120 deny ip 127.0.0.0 0.255.255.255 any
    130 permit ip any any (5264 matches)
    10 permit udp any host 192.168.2.200 eq non500-isakmp
    20 permit udp any host 192.168.2.200 eq isakmp
    30 permit esp any host 192.168.2.200
    40 permit ahp any host 192.168.2.200
    50 permit udp host 103.12.12.14 eq ntp host 192.168.2.200 eq ntp
    60 deny ip 10.1.10.0 0.0.0.3 any
    70 deny ip 192.168.3.0 0.0.0.255 any
    110 permit ip any any (21223 matches)
    50 permit udp host 103.12.12.14 eq ntp host 10.1.1.1 eq ntp
    60 permit tcp 10.1.10.0 0.0.0.3 any eq 2000 (21170 matches)
    70 permit udp 10.1.10.0 0.0.0.3 any eq 2000
    80 deny ip 10.1.10.0 0.0.0.3 any (149 matches)
    90 deny ip 192.168.2.0 0.0.0.255 any
    100 deny ip 192.168.3.0 0.0.0.255 any
    130 permit ip any any (132193 matches)
    20 permit udp host xx.xx.xx.xx host 192.168.3.200 eq non500-isakmp (12304 matches)
    30 permit udp host xx.xx.xx.xx host 192.168.3.200 eq isakmp (15 matches)
    40 permit esp host xx.xx.xx.xx host 192.168.3.200
    50 permit ahp host xx.xx.xx.xx host 192.168.3.200
    60 permit udp any host 192.168.3.200 eq non500-isakmp (4 matches)
    70 permit udp any host 192.168.3.200 eq isakmp (1 match)
    80 permit esp any host 192.168.3.200
    90 permit ahp any host 192.168.3.200
    100 permit udp host 103.12.12.14 eq ntp host 192.168.3.200 eq ntp
    110 deny ip 10.1.10.0 0.0.0.3 any
    120 deny ip 192.168.2.0 0.0.0.255 any (19 matches)
    130 deny ip 10.1.1.0 0.0.0.255 any
    140 permit udp host 192.168.3.1 eq domain any
    150 permit icmp any host 192.168.3.200 echo-reply
    160 permit icmp any host 192.168.3.200 time-exceeded
    170 permit icmp any host 192.168.3.200 unreachable (20 matches)
    180 deny ip 10.0.0.0 0.255.255.255 any
    190 deny ip 172.16.0.0 0.15.255.255 any
    220 deny ip host 0.0.0.0 any
    230 deny ip any any log (492 matches)
    10 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255 (23430 matches)
    10 permit ip 192.168.2.0 0.0.0.255 any
voice service voip
sip
  no update-callerid
voice class codec 1
voice class h323 1
  call start slow
rule 1 /.*/ //
rule 1 /^9/ //
rule 1 /^82\(...\)/ /\1/
rule 1 /\(^...$\)/ /82\1/
rule 1 /^6/ //
policy-map queue
class signaling
  bandwidth percent 5
class media
  priority percent 50
class class-default
  fair-queue
policy-map shape
class class-default
encr 3des
hash md5
group 2
lifetime 1800
description Site1
match address 105
qos pre-classify
interface Loopback0
bandwidth 1024
ip address 192.168.3.200 255.255.255.0
ip nat outside
ip verify unicast reverse-path
load-interval 30
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.200 255.255.255.0
h323-gateway voip bind srcaddr 192.168.2.200
interface Vlan100
ip local pool SDM_POOL_1 192.168.2.201 192.168.2.205
ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.3.1
description **CCA*INTERSITE inbound call to Site2
incoming called-number 82...
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
description **CCA*INTERSITE outbound calls to Site1
destination-pattern 81...
session target ipv4:192.168.0.101
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
UC_520#show crypto session
Crypto session current status
Interface: FastEthernet0/0
Session status: UP-ACTIVE
Peer: xx.xx.xx.xx port 4500
  IKEv1 SA: local 192.168.3.200/4500 remote xx.xx.xx.xx/4500 Active
  IPSEC FLOW: permit ip 192.168.2.0/255.255.255.0 192.168.0.0/255.255.255.0
        Active SAs: 2, origin: crypto map
UC_520#exit
What is the network topology? It appears the UCs are behind another firewall, correct?
-john
Hello again, yup the routers UCs are behind a linksys wag120n ADSL modem
So the UCs are local to each other? Is there any firewall or access-list on the wag120n? Can you connect the UCs directly to each other with a crossover cable or hub?
-john
nope they are connected through internet with real ips, the wag120n is a normal adsl modem nothing special just port forwarded 4500 tcp/udp 500 tcp/udp, vpn passthrough is enabled by default, i even tried ezvpn and its working normally, what are the possible causes ?
I'm not sure this is going to work behind that type of modem/router. You need to have ESP, IP Protocol 50, opened as well. Can you bridge the modem so that the UCs can get the public IPs and bypass the firewall on the wag120n?
-john
well i have already tried it and it didnt work, you mean there is nothing wrong with the config ??
For the most part.
I do see an issue with this on the dial-peers: corlist incoming call-internal
Can you remove the corlist from all the multisite dial-peers and test again?
-john
I just tried it, all multisite dial-peers have no corlist now and still same issue
thanks
Can you post your NAT configuration?
-john
sorry for the late response but i did try few stuff and though i'd get back when i'm done, here is the nat and interface rules:
site 2:
interface Loopback0
ip nat inside
bandwidth 512
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
ip local pool SDM_POOL_1 192.168.2.205 192.168.2.210
ip http server
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
site 1:
interface Loopback0
ip nat inside
bandwidth 1024
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
ntp broadcast
ip local pool SDM_POOL_1 192.168.0.201 192.168.0.205
ip http server
ip dns server
Hi Muhieddine,
Just further to John's request, can you please confirm if the Linksys support H.323 passthrough? If not you may need to also do some port forwarding or Port Triggering for the H.323 as the Linksys could be blocking them, even in Bridged mode (That is just from past experience).
Other than that I dont see a problem with the configuration, not that I have spotted yet but I am looking at it a little further though.
Cheers,
David Trad.
davidtradconsultinggmail.com
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hello David, i tried your solution and still have the same problem :s
thanks
