10-03-2013 08:06 AM - edited 03-21-2019 07:49 AM
Good morning sirs,
I finish config my uc but isnt make call to voip server, just to pstn. I put the preference as 1 to sip and 10 to pstn.
I dial and wait and wait.... and go by pstn. On my sip server my uc show me ok in registar and dont have no one try to calls going to server.
When I made a dial plan test its show me go by sip and after pstn. So my dial plan is ok, i think.
I believe its is firewall problem. Have a command to debug a sip voip call ? to see where its stop?
And could I test a acl? On Asa I have this command. :S
Any help is welcome! thanks so much.
Solved! Go to Solution.
10-07-2013 05:13 PM
Hello Pedro,
You may try to add first choice to voice class codec to be g729r8 because in the other working one you are using g729r8 codec (this is the default in the dialpeer when nothing else is set) as far as I can see.
HTH,
Alex
*Please rate helpful posts
10-03-2013 04:55 PM
Hello Pedro,
Are the incoming calls working?
Best regards,
Alex
10-04-2013 04:47 AM
Yeah, normally work. I think was the firewall, but I remove all rules to test and isnt is. Now I belive is the dial plan. I remove all dial plans and put just one to work and the calss leave.
But with extremelly delay to start call. Anyone know why this problem is now?
thanks too much.
10-04-2013 08:58 AM
I repair to work but I exclude many lines. I dont know what can be. Just to compair, I will put the original conf with the repair conf.
The original conf is the first.
stcapp ccm-group 1
stcapp
isdn switch-type primary-net5
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
registrar server expires max 3600 min 3600
localhost dns:restrict
outbound-proxy dns:restrict
no update-callerid
sip-profiles 1000
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 17
time-format 24
date-format D/M/Y
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 4
rule 15 /^....$/ /1234xxx/
voice translation-rule 6
rule 1 /xx00/ /xx00/
rule 2 /xx01/ /xx01/
rule 3 /xx02/ /xx02/
rule 4 /xx03/ /xx03/
rule 5 /xx04/ /xx04/
rule 6 /xx05/ /xx05/
rule 7 /xx06/ /xx06/
rule 8 /xx07/ /xx07/
rule 9 /xx08/ /xx08/
rule 10 /xx09/ /xx09/
voice translation-rule 7
rule 1 /xx10/ /xx10/
rule 2 /xx11/ /xx11/
rule 3 /xx12/ /xx12/
rule 4 /xx13/ /xx13/
rule 5 /xx14/ /xx14/
rule 6 /xx15/ /xx15/
rule 7 /xx16/ /xx16/
rule 8 /xx17/ /xx17/
rule 9 /xx18/ /xx18/
rule 10 /xx19/ /xx19/
voice translation-rule 8
rule 1 /xx20/ /xx20/
rule 2 /xx21/ /xx21/
rule 3 /xx22/ /xx22/
rule 4 /xx23/ /xx23/
rule 5 /xx24/ /xx24/
rule 6 /xx25/ /xx25/
rule 7 /xx26/ /xx26/
rule 8 /xx27/ /xx27/
rule 9 /xxxx/ /xxxx/
rule 10 /xx29/ /xx29/
voice translation-rule 9
rule 1 /xx30/ /xx30/
rule 2 /xx31/ /xx31/
rule 3 /xx32/ /xx32/
rule 4 /xx33/ /xx33/
rule 5 /xx34/ /xx34/
rule 6 /xx35/ /xx35/
rule 7 /xx36/ /xx36/
rule 8 /xx37/ /xx37/
rule 9 /xx38/ /xx38/
rule 10 /xx39/ /xx39/
voice translation-rule 10
rule 1 /xx40/ /xx40/
rule 2 /xx41/ /xx41/
rule 3 /xx42/ /xx42/
rule 4 /xx43/ /xx43/
rule 5 /xx44/ /xx44/
rule 6 /xx45/ /xx45/
rule 7 /xx46/ /xx46/
rule 8 /xx47/ /xx47/
rule 9 /xx48/ /xx48/
rule 10 /xx49/ /xx49/
voice translation-rule 11
rule 1 /xx50/ /xx50/
rule 2 /xx51/ /xx51/
rule 3 /xx52/ /xx52/
rule 4 /xx53/ /xx53/
rule 5 /xx54/ /xx54/
rule 6 /xx55/ /xx55/
rule 7 /xx56/ /xx56/
rule 8 /xx57/ /xx57/
rule 9 /xx58/ /xx58/
rule 10 /xx59/ /xx59/
voice translation-rule 12
rule 1 /xx60/ /xx60/
rule 2 /xx61/ /xx61/
rule 3 /xx62/ /xx62/
rule 4 /xx63/ /xx63/
rule 5 /xx64/ /xx64/
rule 6 /xx65/ /xx65/
rule 7 /xx66/ /xx66/
rule 8 /xx67/ /xx67/
rule 9 /xx68/ /xx68/
rule 10 /xx69/ /xx69/
voice translation-rule 13
rule 1 /xx70/ /xx70/
rule 2 /xx71/ /xx71/
rule 3 /xx72/ /xx72/
rule 4 /xx73/ /xx73/
rule 5 /xx74/ /xx74/
rule 6 /xx75/ /xx75/
rule 7 /xx76/ /xx76/
rule 8 /xx77/ /xx77/
rule 9 /xx78/ /xx78/
rule 10 /xx79/ /xx79/
voice translation-rule 14
rule 1 /xx80/ /xx80/
rule 2 /xx81/ /xx81/
rule 3 /xx82/ /xx82/
rule 4 /xx83/ /xx83/
rule 5 /xx84/ /xx84/
rule 6 /xx85/ /xx85/
rule 7 /xx86/ /xx86/
rule 8 /xx87/ /xx87/
rule 9 /xx88/ /xx88/
rule 10 /xx89/ /xx89/
voice translation-rule 15
rule 1 /xx90/ /xx90/
rule 2 /xx91/ /xx91/
rule 3 /xx92/ /xx92/
rule 4 /xx93/ /xx93/
rule 5 /xx94/ /xx94/
rule 6 /xx95/ /xx95/
rule 7 /xx96/ /xx96/
rule 8 /xx97/ /xx97/
rule 9 /xx98/ /xx98/
rule 10 /xx99/ /xx99/
voice translation-rule 410
rule 1 /^0\(.*\)/ /\1/
rule 15 /^....$/ /134711/
voice translation-rule 411
rule 1 /^0\(.*\)/ /ABCD0\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^0/ //
voice translation-rule 2000
rule 1 /xx99/ /xx99/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile DDR_Called_10
translate calling 3265
translate called 10
voice translation-profile DDR_Called_11
translate called 11
voice translation-profile DDR_Called_12
translate called 12
voice translation-profile DDR_Called_13
translate called 13
voice translation-profile DDR_Called_14
translate called 14
voice translation-profile DDR_Called_15
translate called 15
voice translation-profile DDR_Called_6
translate called 6
voice translation-profile DDR_Called_7
translate called 7
voice translation-profile DDR_Called_8
translate called 8
voice translation-profile DDR_Called_9
translate called 9
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile VM_Profile
translate called 2000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
license udi pid UC560-T1E1-K9 sn restrict
archive
log config
logging enable
logging size 600
hidekeys
username restrict privilege 15 secret 4 restrict
controller E1 0/3/0
pri-group timeslots 1-31
ip tftp source-interface Vlan90
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (restrict) **
session protocol sipv2
session target sip-server
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (restrict) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
session target ipv4:10.1.10.1
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^....$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1026 voip
corlist outgoing call-international
description **CCA*Brazil*International Calls**
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 000T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 58 pots
trunkgroup ALL_T1E1
description **CCA*Brazil*local**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 0[2-4]T
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 10xx voip
dial-peer voice 1020 voip
description **CCA*Brazil*Celular teste**
preference 1
destination-pattern 09748....
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 60 pots
trunkgroup ALL_T1E1
description **CCA*Brazil*Celluar 8 digitos**
preference 3
destination-pattern 0[5-9].......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
no dial-peer outbound status-check pots
sip-ua
credentials username user pass realm
keepalive target dns:dns
authentication username user passs
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar dns:dns expires 3600
sip-server dns:dns
host-registrar
g729-annexb override
REPAIR CONF
stcapp ccm-group 1
stcapp
trunk group ISDN1
description ISDN Interfaces 1
voice rtp send-recv
voice service voip
no supplementary-service sip handle-replaces
h323
call service stop forced
sip
registrar server expires max 900 min 900
outbound-proxy dns:dns
voice class codec 1
no-circuit
mode cme
timezone 17
time-format 24
date-format D/M/Y
rule 1 /^0\([2-9].......\)/ /21\1/
rule 2 /^0726/ /sipnumber/
rule 3 /^00[^0][^0]\([^0][^0][^01].......\)/ /\1/
rule 4 /^000[^0][^0]1\(..........\)/ /001\1/
rule 5 /^000[^0][^0]\(.*\)/ /00\1/
rule 1 /^6/ //
voice translation-profile Outgoing-VOIP
translate called 2
voice-card 0
dspfarm
license udi pid UC560-T1E1-K9 sn Restrict
archive
log config
logging enable
logging size 600
hidekeys
username Restrict privilege 15 secret 4 Restrict
controller E1 0/3/0
no ip address
encapsulation hdlc
isdn supp-service name calling
isdn outgoing ie redirecting-number
trunk-group ISDN1 1
no cdp enable
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtpRestrictd6620
associate profile 1 register confprof1
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Restrict
codec g711ulaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum sessions 4
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-fax
member PSTN-fax
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern xx99
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
destination-pattern xx99$
b2bua
codec g711ulaw
no vad
dial-peer voice 1112 pots
destination-pattern xx23
port 0/0/2
dial-peer voice 1113 pots
destination-pattern xx90
port 0/0/3
trunkgroup ALL_T1E1
preference 3
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
preference 1
destination-pattern 09xx8....
dtmf-relay rtp-nte
no vad
trunkgroup ALL_T1E1
preference 3
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 1002 voip
description ***TESTE SIP TRUNK ***
translation-profile outgoing Outgoing-VOIP
preference 1
destination-pattern 0.T
dtmf-relay rtp-nte
sip-ua
credentials username 1user pass realm
authentication username 1user pass realm
no remote-party-id
retry invite 2
retry register 1
timers connect 100
registrar dns:dns expires 900
sip-server dns:dns
I think is a problem with dial peer, but I dont know where exactly is. When I remove the calls go normally.
Please, anyone can help me?
10-07-2013 05:13 PM
Hello Pedro,
HTH,
Alex
10-08-2013 05:54 AM
Hello Alexander, thanks so much, its work now and the priority of trunk on dial peer need changes too
But you help me a lot, thanks againa man!
