Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
999
Need default factory config for UC540W-FXO-K9
Hello
I lost my password to get into my UC540 using CCA.
I used password recovery that the ISR uses, and I am now able to console into the device and am able to get into enable/privileged mode.
But when I copy the default factory config from flash to the startup config in nvram, it does not work.
All I get is a config that shows the interfaces on the UC540W; no voice vlan ip, no data vlan ip, no certificate encryption keys, etc.etc.
This is really strange.
Does somebody have a copy of the default factory config or a text file of the factory config, so in worst case, I can manually add it?
I dont want to manually add it, but the following command does not work:
copy flash:UC540W-FXO-K9-factory-8.2.0.cfg nvram:startup-config
After I run the command above, I reload, then do a sho run, and I do not see the factory configuration with the data vlan ip and the voice vlan ip, etc. etc.
I also tried: copy flash:startup-config.bak nvram:startup-config    and that does not leave me with the correct startup config either.
Please help.
Everyone's tags (1)
1 REPLY 1
Highlighted
argh
I fixed it.
You need to copy the factory config to running config FIRST.
Then wr mem
Then 0x2102
Then reload
Sh*t
too many beers
