Need default factory config for UC540W-FXO-K9
Hello
I lost my password to get into my UC540 using CCA.
I used password recovery that the ISR uses, and I am now able to console into the device and am able to get into enable/privileged mode.
But when I copy the default factory config from flash to the startup config in nvram, it does not work.
All I get is a config that shows the interfaces on the UC540W; no voice vlan ip, no data vlan ip, no certificate encryption keys, etc.etc.
This is really strange.
Does somebody have a copy of the default factory config or a text file of the factory config, so in worst case, I can manually add it?
I dont want to manually add it, but the following command does not work:
copy flash:UC540W-FXO-K9-factory-8.2.0.cfg nvram:startup-config
After I run the command above, I reload, then do a sho run, and I do not see the factory configuration with the data vlan ip and the voice vlan ip, etc. etc.
I also tried: copy flash:startup-config.bak nvram:startup-config    and that does not leave me with the correct startup config either.
Please help.
argh
I fixed it.
You need to copy the factory config to running config FIRST.
Then wr mem
Then 0x2102
Then reload
Sh*t
too many beers
