I have a client who is looking for a telephone system with 20 analog trunk lines (20 FXO) and 30 users. I know that the UC560 can support up to a maximum of 12 FXO's, but is it possible to integrate 2 x SPA8800 along with the UC560 to make it as 20 analog trunk lines?
Ajay
Hi Ajay,
I know you can do 1 but not sure about 2, the problem you may also have is that it requires CLI configuration.
I would highly encourage you to log a SBSC configuration assistance case and have them help you navigate these waters, it may be a little hard to get full and proper support of the forums as you need to also make sure that the CLI configuration will not make CCA go crazy
Cheers,
David.
