Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
746
Ajay Wadhwani
Beginner
Need to integrate SPA8800 with UC560
I have a client who is looking for a telephone system with 20 analog trunk lines (20 FXO) and 30 users. I know that the UC560 can support up to a maximum of 12 FXO's, but is it possible to integrate 2 x SPA8800 along with the UC560 to make it as 20 analog trunk lines?
Ajay
1 REPLY 1
David Trad
Rising star
Hi Ajay,
I know you can do 1 but not sure about 2, the problem you may also have is that it requires CLI configuration.
I would highly encourage you to log a SBSC configuration assistance case and have them help you navigate these waters, it may be a little hard to get full and proper support of the forums as you need to also make sure that the CLI configuration will not make CCA go crazy
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
