04-12-2011 05:07 AM - edited 03-21-2019 03:56 AM
I did a factory restore and reinstall on UC560 using CCA3.0(1) last Friday.
It was working fine on that day. But Monday morning except one phone all other phones start downloading files.
Then did a restart on UC560 all back online and worked. Then again Tuesday middle of the day it started to do the same thing. One phone registered all other phones are deceased, so I had to restart the UC560 and ESW switch again.
uc560 is directly connected to internet through a four port switch. all the phones are connected to ESW-520, and that is connected to UC560.
ANY Idea
shameer
Solved! Go to Solution.
04-12-2011 04:59 PM
Hi Shameer,
I was going to respond to your e-mail till I seen your post, it is best to deal with this on the forums so you can be helped by more than one person
After having looked at the network topology and remotely looked at how things are configured I would need to ask the following questions:
Since we last spoke has the network topology changed? The previous configuration might have been setup the way it was due to this very reason, but this does not mean it is right and you just need to narrow down on what is causing this problem and actually fix it instead of masking the problem with a work around, such as the way it was done before you coming onto the scene and taking on the task of re-building the system.
Lets start with the above questions before we move onto other ones.
Cheers,
David.
04-14-2011 03:00 AM
Hi Shameer,
I am glad it is all working now for you
The other issue you emailed me to me might also be best to ensure it is up on the forums as well, but I will still try to help you with it if I can but just invade I am busy or asleep, having others comment might get your problem resolved quicker
If this particular issue is now resolved can i please ask for you to mark the thread as answered so others may benefit from it with searches.
Cheers,
David.
04-12-2011 12:17 PM
I had similar stuff happened a while ago at a client. It was certainly not this bad, but similar. I replaced all the uplink cables to high quality CAT6 cables. It has been a long time (months) that this crazy stuff has not happened.
Also, confirm, when the phones are down, can you ping the UC and CUE from a computer which is connected via a phone. Double check your VLAN settings and make sure there is no other DHCP for voice VLAN besides the UC.
Are you using SPA phones or some other series.
04-12-2011 04:59 PM
Hi Shameer,
Cheers,
David.
04-14-2011 02:33 AM
Hi David
thanks for your post. managed to fix the problem.
1.s there is an ip dhcp pool on UC, but the ESW switch is getting an Ip address from SA520 on data netword.
2.so the CCA topology was showing SA520 as well. then i figure out there is a cable connection between the dummy switch and ESW. So removed the cable. and restart. then the ESW
got ip from UC560.
3.en check the ESW software image (1.0v) and boot loader (1.0.0.02). upgrade the to latest versions 2.1.1.9 and boot 1.0.0.04.
now the telephone system working fine. thanks for your valuable support
thanks
shameer
04-14-2011 03:00 AM
Hi Shameer,
Cheers,
David.
