01-24-2012 08:51 PM - edited 03-21-2019 05:14 AM
I got UC520 to setup & used in office, i have configured it, & I have checked Internet on Router it's working fine, I can ping Outside from console but no buddy can access Internet from UC520 by LAN because System's are not getting IP from DHCP Server also we are unable to found WiFi signal of UC520 from any Laptop, I am not sure if I'm wrong in Configuration
Can anyone help me?
Thanks in Advance
UC520#sh run Building configuration... Current configuration : 4834 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname UC520 ! boot-start-marker boot-end-marker ! enable secret 5 XXXXXXXXXXXXXXXXXX ! no aaa new-model network-clock-participate wic 1 ! ! ! ! ! dot11 ssid KiwiKrane-voice vlan 100 authentication open authentication key-management wpa wpa-psk ascii 7 XXXXXXXXXXXXXXXXXX ! dot11 ssid Kiwikrane vlan 1 authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 XXXXXXXXXXXXXXXXXX ! ip cef ! ! ip dhcp relay information trust-all no ip dhcp use vrf connected ip dhcp excluded-address 192.168.6.1 192.168.8.10 ip dhcp excluded-address 10.10.11.1 10.10.11.10 ! ip dhcp pool DATA network 192.168.6.0 255.255.255.0 default-router 192.168.6.1 dns-server 8.8.8.8 8.8.4.4 ! ip dhcp pool VOICE network 10.10.11.0 255.255.255.0 default-router 10.10.11.1 option 150 ip 10.1.1.1 ! ! no ip domain lookup ip name-server 203.109.129.67 ip name-server 203.109.129.68 ip name-server 8.8.8.8 ip name-server 8.8.4.4 ! ! multilink bundle-name authenticated ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! voice-card 0 no dspfarm ! ! ! username XXXXXXXXXXXXXXXXXX privilege 15 password 7 XXXXXXXXXXXXXXXXXX archive log config hidekeys ! ! bridge irb ! ! ! interface FastEthernet0/0 description -= WAN PORT =- ip address 192.168.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto ! interface Integrated-Service-Engine0/0 no ip address shutdown ! interface FastEthernet0/1/0 switchport voice vlan 100 macro description cisco-phone | Cisco 7960 ! interface FastEthernet0/1/1 description -= Switch =- switchport trunk allowed vlan 1,100,1002-1005 switchport mode trunk ! interface FastEthernet0/1/2 ! interface FastEthernet0/1/3 ! interface FastEthernet0/1/4 ! interface FastEthernet0/1/5 switchport voice vlan 100 macro description Cisco 7906 ! interface FastEthernet0/1/6 switchport voice vlan 100 macro description Cisco 7906 ! interface FastEthernet0/1/7 switchport voice vlan 100 macro description Cisco 7906 ! interface FastEthernet0/1/8 ! interface BRI0/1/0 no ip address ! interface BRI0/1/1 no ip address ! interface Dot11Radio0/5/0 no ip address ip virtual-reassembly ! encryption vlan 100 mode ciphers tkip ! encryption vlan 1 mode ciphers tkip ! ssid KiwiKrane-voice ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root world-mode dot11d country NZ both bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio0/5/0.1 encapsulation dot1Q 100 bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio0/5/0.2 encapsulation dot1Q 1 native bridge-group 2 bridge-group 2 subscriber-loop-control bridge-group 2 spanning-disabled bridge-group 2 block-unknown-source no bridge-group 2 source-learning no bridge-group 2 unicast-flooding ! interface Vlan1 no ip address ip virtual-reassembly bridge-group 2 bridge-group 2 spanning-disabled ! interface Vlan100 no ip address ip virtual-reassembly bridge-group 1 bridge-group 1 spanning-disabled ! interface Dialer1 no ip address ! interface BVI1 ip address 10.10.11.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface BVI2 ip address 192.168.6.1 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1380 ! ip route 0.0.0.0 0.0.0.0 192.168.0.1 ! ip http server no ip http secure-serverip nat inside source list NAT-ALLOWED interface FastEthernet0/0 overload
!ip access-list extended NAT-ALLOWED
deny ip any 10.0.0.0 0.255.255.255
permit ip 192.168.6.0 0.0.0.255 any
! ! ! ! ! ! control-plane ! ! ! voice-port 0/0/0 ! voice-port 0/0/1 ! voice-port 0/0/2 ! voice-port 0/0/3 ! voice-port 0/1/0 ! voice-port 0/1/1 ! voice-port 0/2/0 ! voice-port 0/2/1 ! voice-port 0/2/2 ! voice-port 0/2/3 ! voice-port 0/4/0 auto-cut-through signal immediate input gain auto-control description Music On Hold Port ! ! ! ! ! !
