Not able to receive call from SIP provider to my UC540. Outgoing calls working fine
eduardmuni
One month ago, I start using my UC540 with a Voice Ip carrier to do some tests. The carrier is Vozelia in spain.
After configuring the trunk it starts working finde, making and receiving calls.
One week ago inbound calls start failing. I told the carrier and it told me that my uc540 is incorrectly registered. Outgoing calls are working fine.
To test de carrier Iconfigure the trunk in a 3cx that I have in the same network, and in less than five minutes both outgoing and incoming calls start working fine.
I've restored the uc540 to factory and configured it three times, and every time with the same issue. It's impossible for me to solve this problem.
Can you help me?
Thanks a lot.
eduardmuni
OK. Here I'm.
Anyone can help me? It's so important for me to solve this problem.
Thank U very much
Ed
Hi Ed,
How is the UC540 connected to the internet -WAN or LAN through another gateway?
Are you using firewall? Is this the firewall of the UC or another device?
Do you need registration with the SIP provider?
How did you configure UC540 CCA or CLI?
Did you check the incoming access-list from the internet and the dial-peer(s) for incoming SIP calls?
You can try these steps to verify if you have configured with CCA:
1. Open your firewall just for the test - add this line to access list 104 e.g. Through CLI or CCA "5 permit ip any any". If after this you can get the calls then you can create more specific rules to your 104 access-list for your SIP service provider servers.
2. If the previuos is not working - Run "show sip-ua reg stat" if you have registered with the SIP provider. If you need to be registered go to the next step and run only the first command.
3. Run debug "debug ccsip messages" and "debug ccapi inout" and post it here with relevant configuration while removing passwords and changing ip addresses.
HTH,
Alex
Hi Alex,
Thank's for you help. Here are my answers:
- How is the UC540 connected to the internet -WAN or LAN through another gateway?
Just conected to the ISP router. The Uc540 Wan interface is connected to the router as DMZ with all ports redirected.
-Are you using firewall? Is this the firewall of the UC or another device? No, Only the UC540 as a firewall
- Do you need registration with the SIP provider? Yes and It works perfect for the outgoing calls
- How did you configure UC540 CCA or CLI? The initial config with CCA.
- Did you check the incoming access-list from the internet and the dial-peer(s) for incoming SIP calls?
Yes, I think it's correct. Here it is (192.168.1.200 is the Wan Ip address, and 80.91.83.25 is the Sip provider IP)
Extended IP access list 104
    10 permit udp host 80.91.83.25 eq 5060 any
    20 permit udp host 80.91.83.25 any eq 5060
    30 permit udp any any range 16384 32767
    40 deny ip 10.1.10.0 0.0.0.3 any
    50 deny ip 10.1.1.0 0.0.0.255 any
    60 deny ip 192.168.10.0 0.0.0.255 any
    70 permit udp host 8.8.8.8 eq domain any
    80 permit udp host 8.8.8.4 eq domain any
    85 permit tcp any host 192.168.1.200 eq 443
    90 permit icmp any host 192.168.1.200 echo-reply
    100 permit icmp any host 192.168.1.200 time-exceeded
    110 permit icmp any host 192.168.1.200 unreachable
    120 deny ip 10.0.0.0 0.255.255.255 any
    130 deny ip 172.16.0.0 0.15.255.255 any
    140 deny ip 192.168.0.0 0.0.255.255 any
    150 deny ip 127.0.0.0 0.255.255.255 any
    160 deny ip host 255.255.255.255 any
    170 deny ip host 0.0.0.0 any
1.- I added the line 5 permit ip any any and it doen's works
2.-
UC_540#show sip-ua reg stat
Line                             peer       expires(sec) registered P-Associ-URI
161200                           20002      2791         yes
3.- debug ccsip messages (the debug ccapi inout is correct? Is not working for me)
UC_540#  sh log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 3191 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 297 message lines logged
Log Buffer (512000 bytes):
002334: Mar 25 08:11:15.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:161200@192.168.1.200:5060 SIP/2.0
Via: SIP/2.0/UDP 80.91.83.25:5060;branch=z9hG4bK5183900c;rport
Max-Forwards: 70
To: <161200>
Contact:
Call-ID: 45e8006f2036d3f9277ba17a08591087@80.91.83.25:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-2.8.1(1.8.9.0)
Date: Sun, 25 Mar 2012 08:14:37 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Content-Length: 0
002335: Mar 25 08:11:15.138: //9881/EB4A57AAA6B5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <161200>;tag=8296DA0-191
Date: Sun, 25 Mar 2012 08:11:15 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 148
v=0
o=CiscoSystemsSIP-GW-UserAgent 4474 6079 IN IP4 192.168.1.200
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 192.168.1.200
002336: Mar 25 08:11:16.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <161200>
Contact:
CSeq: 102 OPTIONS
Content-Length: 0
002337: Mar 25 08:11:16.138: //9881/EB4A57AAA6B5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 25 Mar 2012 08:11:16 GMT
CSeq: 102 OPTIONS
Content-Length: 148
v=0
s=SIP Call
t=0 0
002338: Mar 25 08:11:26.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 80.91.83.25:5060;branch=z9hG4bK1a009f87;rport
Max-Forwards: 70
To: <161200>
Contact:
Call-ID: 26e22b031862968d1503a6fb3d5419d5@80.91.83.25:5060
CSeq: 102 OPTIONS
Date: Sun, 25 Mar 2012 08:14:51 GMT
Content-Length: 0
002339: Mar 25 08:11:26.142: //9882/F3A292AAA6B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <161200>;tag=829A44C-1A2D
Date: Sun, 25 Mar 2012 08:11:26 GMT
CSeq: 102 OPTIONS
Content-Length: 154
v=0
o=CiscoSystemsSIP-GW-UserAgent 2521 4294965785 IN IP4 192.168.1.200
s=SIP Call
t=0 0
002340: Mar 25 08:11:27.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <161200>
Contact:
CSeq: 102 OPTIONS
Content-Length: 0
002341: Mar 25 08:11:27.138: //9882/F3A292AAA6B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 25 Mar 2012 08:11:27 GMT
CSeq: 102 OPTIONS
Content-Length: 154
v=0
s=SIP Call
t=0 0
002342: Mar 25 08:11:28.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <161200>
Contact:
CSeq: 102 OPTIONS
Content-Length: 0
002343: Mar 25 08:11:28.138: //9882/F3A292AAA6B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 25 Mar 2012 08:11:28 GMT
CSeq: 102 OPTIONS
Content-Length: 154
v=0
s=SIP Call
t=0 0
002344: Mar 25 08:11:29.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <161200>
Contact:
CSeq: 102 OPTIONS
Content-Length: 0
002345: Mar 25 08:11:29.138: //9882/F3A292AAA6B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 25 Mar 2012 08:11:29 GMT
CSeq: 102 OPTIONS
Content-Length: 154
v=0
s=SIP Call
t=0 0
002346: Mar 25 08:11:30.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <161200>
Contact:
CSeq: 102 OPTIONS
Content-Length: 0
002347: Mar 25 08:11:30.138: //9882/F3A292AAA6B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 25 Mar 2012 08:11:30 GMT
CSeq: 102 OPTIONS
Content-Length: 154
v=0
s=SIP Call
t=0 0
002348: Mar 25 08:11:40.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 80.91.83.25:5060;branch=z9hG4bK1272c18d;rport
Max-Forwards: 70
To: <161200>
Contact:
Call-ID: 763804316f9f191e1a4724907a5bfdd4@80.91.83.25:5060
CSeq: 102 OPTIONS
Date: Sun, 25 Mar 2012 08:15:05 GMT
Content-Length: 0
002349: Mar 25 08:11:40.138: //9883/FBFACDAAA6B7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <161200>;tag=829DAFC-B1
Date: Sun, 25 Mar 2012 08:11:40 GMT
CSeq: 102 OPTIONS
Supported:
Here ir the log.
as I see, it seems that incoming trafic arrives for Unknosn. Is this normal?
Thanks for all,
Eduard
Can you include a 'debug ccsip messages' for a working call?  Was the above trace from a non-working inbound call?
