02-08-2016 02:10 AM - edited 03-21-2019 08:51 AM
Hii
Im implementing CUCM on BE6K system and i would like to buy CUWL-PRO for personal multiparty ,
Im confused to oreder CUWL-PRO using the R-CBE6K-K9 top-level for BE6K of use CUWL-PRO-K9 top-level to order
what is the difference ?
Solved! Go to Solution.
02-12-2016 04:11 PM
Hi Guys,
Blaine, that's not entirely correct. R-CBE6K-K9 allows you to buy licenses for use with a BE6000 server (there are no server licenses as such). In this respect, there is functionally no difference between licenses ordered via CUWL-PRO-K9 and R-CBE6K-K9.
Hesham, in your case, as you are deploying on a BE6000 server - and therefore have less than 1000 users - you should use the R-CBE6K-K9 option. (Don't forget to check the "FIRST-PRO" license option if this is your first CUWL-PRO order.)
Andy
02-11-2016 07:18 AM
The difference in the licensing is that the CUWL-PRO-K9 license is for the CUWL user licenses and the R-CBE6K-K9 is the license for the actual server itself.
Cisco also offers a CUWL Pro starter bundle of 35 licenses (BE6K-START-PRO35) that can save you some money if you need at least 35 licenses.
B
02-12-2016 04:11 PM
Hi Guys,
Andy
